Where should I start????
Hey everyone, ive just registered so im not sure if theres already a thread about this so·someone tell me if there is please
im only 16 and recently ive discovered through different places that i really really like building robotic machines, but i have no idea where to start with things, ive built a few mini robots i found on youtube using simple switches, solar panels, capacitors and motor combinations, but i fancy something a bit better, so i found this site, anyone got any ideas of what i should try? any sites that have instructions? or books for that matter
welcome to the forums - you are in good company now [noparse]:)[/noparse]· Spend some time here reading posts - and not just in the Robotics section. You'll find the entire range of things you might want to know. There's alot of smart, friendly and helpful people here. And more than a few about your age.
Here's a fun and useful trick some of the more experienced forum users do.··Use the forum 'index' to see what other forum users are currently reading.· [noparse]:)[/noparse])· It's the "details" link down in the bottom left corner, just above the names of folks online.
Happy hunting!
- Howard
PG
http://search.parallax.com
I just tried searching there with:
cheap dc motors
and got quite a few hits. Try the same on google, of course. Some of our better informed folks might chime in here with some suggestions of specific surplus places. You can always try Jameco.com - they have some nice 'surprise' bags of parts, including motors. Another idea is to get some cheap, near throw away motorized toys and hack them for parts. Many of us here are not adverse to electronics dumpster diving [noparse]:)[/noparse])
[noparse][[/noparse]EDIT: forgot to mention the obvious: your public library!· They might have some of the Robot Bonanza books which lists tons and tons of resources.]
solarbotics.com has pager motors with a gearbox attached
pololu.com has a lot of small motors with gearbox http://www.pololu.com/catalog/category/51 they are about 1" long with a range of gearing for almost any rpm you want. I have used these before and have had no problems with these.
You can also get motors surplus though I dont rememer seeing any pager motors with gearboxes but they have pager motors without gearboxes try
allelectronics.com
bgmicro.com
goldmine-elec.com
The other place to look is robotmaketplace.com they have a pretty big range of motors though not many that small - look in their antbot section for small motors.
PG
i dont need the gearbox, but ill try anything, just the cheapest i can get basically
btw--cheapest you can get is going to a thrift store and buying old vcrs and toys. I got a vcr at one once and didn't realize it was broken, but didn't mind when I got 3 motors from it, two of which were brushless and worked just fine from 5v to 30v. Pretty good deal for 3 US $.
PG
PG
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
im 16 too, once i found this website i went all out and began attempting building robots from scrap. Right now im finishing up a sumo bot that i built from scracht and a parallax basic stamp. The beuty of mini sumo is that they could be redisigned for lots of applications.
BOB55
"or books for that matter"
idk what your future plans are, but one book I suggest trying out is "123 Pic Microcontroller Experiments for the Evil Genius." It's a little on the complex side of things but it teaches you C and goes from displaying messages on an lcd to making a robot out of a Zip Zap rc car. I've just started working with it, but I've enjoyed every bit of it and plan to move my C knowledge to other micros like the arduino and maybe even on the Propeller if I can get the money for the programmer.
PG
Good luck and have fun in the exciting world of robotics!
MacGeek117
BS2: $49
SX48 Protoboard: $10
Propeller Protoboard: Priceless
www.apple.com
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.jameco.com
The drivers for the USB-to-Serial Adapter should have automatically installed with the latest version of the BASIC Stamp Editor. May I ask what board and power supply you are using?
Thanks!
-- Jessica
Jessica Uelmen
Education Department
Parallax Inc.
http://www.parallax.com/Store/Education/KitsandBoards/tabid/182/CategoryID/67/List/0/SortField/0/Level/a/ProductID/294/Default.aspx
and ive got a new 9v battery connected to it, a friend said maybe it was damaged by static? if thats right can it be repaired? or would i need to get a new one? that would suck [noparse]:([/noparse]
thanks for all help so far btw [noparse]:D[/noparse]
There is always a potential for damage due to static, but it is unlikely. Have you double checked that your BASIC Stamp is mounted in its socket correctly, and that none of the pins have accidentally been bent under the module? I know it seems trivial, but from experience, it is a problem that we run into fairly frequently.
If that's not the case, we do have a great Troubleshooting section now built into our BASIC Stamp Editor Help. In the Stamp Editor, click Help -> BASIC Stamp Help..., and then select the "Getting Started with Stamps in Class" link on the bottom right of the welcome screen.
Once you've selected your board and gone through a couple of introductory pages, you'll then be taken through some of the most common problems our Tech Support team runs into when helping out our customers. And if none of that works, we provide quick links for contacting our Tech Support team. [noparse]:)[/noparse]
Best of luck, and let us know if you run into any other problems!
-- Jessica
Jessica Uelmen
Parallax Inc.
