Rocket Payload
·I have attached all the code and schematics of a Flight computer that reads and stores accelerometer data.
The data is downloaded using a Visual Basic App.(Thanks Jeff)
Any input?
Any input?
Here is a pic of the board
I see you had a board made. Do you plan to sell the boards?
The Max 187 sounds like the answer to a question I've had about Vref for analog devices. The internal reference voltage works well for you? Those are 8-pin DIP packages?
The flights were at Tripolli Minnesota's Northbranch launch.
No I don't plan on selling the boards but I can provied a link for them from BatchPCB. They will break mach so I figured a board would be a good idea.
·The Vref has worked fine.· Yes they are 8 DIP.
·It wouldn't take more than an upgraded moduel and a GPS connected to the expansion header to have that info as well.
Post Edited (Mike15) : 8/3/2009 5:19:27 PM GMT
·As for the rise in output from the MMA:
· 1. I do not have signal diodes
· 2. The differance in orientation from the vertical axis at apogee
Any other suggestions on what caused this?
Chris Savage
Parallax Engineering
