Through-hole plating: how to?
xanatos
Since I'm about to invest in a reflow soldering station, and now have the ability to make some very fine run PC boards, the final skill I need to start making some really cool stuff is to be able to do through-hole plating so I am not spending time soldering little wire bits through all the pass-throughs. Does anyone have or know of a preferred technique for doing this?
Thanks!
Dave X
Thanks!
Dave X
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks!
Dave
- Stephen
Dave
So.... one last time.... does anyone have any info on HOW to plate my own vias? I'm gathering that the answer is probably not...???
Best,
Dave
www.megauk.com/through_hole_plating.php
It's rather expensive at £5145, and other equipment is needed.
Leon
Leon - that link was actually immensely helpful, and gave me sufficient keywords to search out to refine my search, and to find some things that may be exactly what I am looking for. Basically it's a three step process that, if it works as I'm hoping, will do the job perfectly. First step is to apply a sealer into each hole to be plated to seal the fiberglass, next step is a polymer/acrylic high-temp platable base, the last step is a non-electrolysis deposition system that plates the polymer acrylic stuff. These items are not being advertised for this use, but they should work - I'll know when I actually get them and try them out. I'll let you all know!
Dave
Dave
Dave
www.solder.net/marketplace/product_desc.asp?Sku=BEST%20Through-hole%20Repair%20Kit&Category=108
or google "PCB eyelet"
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
