Helicopter shaft design
Hi!
I am concidering building an RC helicopter with counter rotating blades (and Stamp control of course).
I have read somewhere that you can rotate the fuselage by increasing or decreasing the rpm on the blades. This is OK.
The question is: How do I get the copter to move? Do I tilt the rotor shaft? And how many axes do I need?
Since I can rotate the fuselage with rpm adjustments, I thought I'd get away with only one axis.
Don't worry. Be happy
Rich H
They come in all sizes, so you can either·scale up a small one or just buy a large enough one to carry your electronics. Their power-to-weight ratio and energy density of their lithium polymer batteries is quite impressive.
1, Learn to fly first. There are a couple really good RC flight sims out there and helicopters are... not real easy to fly. The bigger they are, the easier they are to fly, unfortunate that they are also more expensive.
2, Try out your funky aircraft designs in X-Plane. You can download the program for free, the Plane Maker program that comes with it has no restrictions (as of version 8 anyway) and the flight sim part will allow you to fly for five minutes before disabling the controls. Plenty of time to try out your designs.
Rich H
