quick and easy memory?
I am making a PCB that will control many switches (1/0 logic) and a few SPI serial potentiometers. I would like to add some memory to be able to save the state of the switches serveral times over (10 or so) to be called later from a input high state, to set all of the outputs.
I don't have any experience with spin or propeller assembly, but I get the basics of programing, basic, lua, php, and some other application specific languages. What would be the easiest way to store these settings? I need maybe 1 kilobyte of space I predict so a 2GB sd card would be overkill, but mainly I'm looking to not spend a whole lot of time trying to figure out how to store the settings.
What would you suggest as being quick and easy? maybe you know of a good Prop object?
Rich H
