high voltage high capacitance for under $60@100
100F@2.5V
can i put 5 in series to get 20F @ 12.5V
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
so if math is correct 9.16V is max safe voltage.
Post Edited (mctrivia) : 7/27/2009 3:07:54 AM GMT
To get 12V with 5 capacitors each one would need to be charged to 2.4V which leaves very little room for error. You would need some additional circuitry to balance the voltage on the capacitors unless you want to find out what an overvoltage 20F capacitor sounds like when it explodes.
Of course you could also try matching the capacitors and hoping that they stay matched as they age.
The conventional solution, which I recommend, is to place a resistor in parallel with each individual capacitor. If the resistors are equal, they will equalize the DC across the capacitors.
Choose a resistance value that will pass perhaps 10-50 times the maximum expected leakage current of the capacitors. That's enough to swamp any differences in leakage among individual capacitors.
· -- Carl, nn5i@arrl.net
*drop voltage to 10v
*place 2.2v zener across each
*place resister accepas each
Zeners?· Heavens, no.
Place a resistor across each capacitor.
Remember, what you're trying to do is equalize the DC across each capacitor.· To do this, you would like to have capacitors that have the same leakage resistance.· Can't buy them that way.· So, you place a resistor across each one, thus increasing its leakage current by decreasing its leakage resistance.
For example, suppose the worst (leakiest) capacitor has a leakage current of 1 μa, and the best one has only 1/10 as much, 0.1 μa.· The best one has ten times as much leakage resistance and would end up with ten times as much DC across it.· Not good.
So you put a resistor across each capacitor, chosen to pass, say, 50 μa.· That effectively increases the leakage of the worst capacitor to 51 μa, and of the best one to 50.1 μa.· Now they differ by only 2%, and the DC will equalize within 2%.· Much better, eh?
Since I have no clue what levels of leakage current you can actually expect (you'll have to find this out), I have no way to recommend specific values of resistance.
Post Edited (Carl Hayes) : 7/27/2009 5:27:52 PM GMT
2.5 volt .0005 uA =·5000 ohms
Will have to compute resisters that will keep bellow 2.5 no matter what.
Now as far as going over 2.5 volt why not put a 12 volt regulator
I would use 6 of those cap and the voltage to each one would be 2 volts with a 5000 ohm resister on each cap
Now I could be wrong BUT I am going to try this set up my self and see how this works because I have some 4.5 F @ 2.5 volt one to Play with
Where did you the one that you are talking about· 100·F @ 2.5 volts
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/27/2009 9:44:38 PM GMT
Where did you the one that you are talking about· 100·F @ 2.5 volts· could you Post a web Link to them
··Thanks for any·
Sam
··Thanks for any·
Sam
Mind divulging what you are using these for? It SOUNDS like some sort of battery backup, but remember - many of these low voltage super-caps have a fairly high ESR. They are usually used as low voltage, low current, battery backup's in circuits.
I need it to supply the 20A 5ms impulse required to blow an ematch under worst case scenario.
my math shows that at 20F even if the power supply was providing nothing to charge the caps the voltage would only drop to about 50%.
EDIT: Never mind - you're talking about the drop across the ESR. Yes, you're right...
Why go to the trouble to put five of these in series instead of just buying a single 20uF @25V? Unless you already have a mess of the 100uF.
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
DJ
Instead of:
I prefer:
http://www.alliedelec.com/Actives-and-Passives/Capacitors/?N=4294821930+4294827693+4294838989+4294821038
DJ
Instead of:
I prefer:
Why do you need 20 Farads, out of curiosity. Limited supply voltage? Is there any chance of providing a higher voltage to charge the cap bank?
At work we use a 7mF (milli Farad) cap bank charged to 63V to deliver up to 100A. At that current, the bank can only sustain it for 300us (auto shutdown forced by design of the instrument). At lower current settings it can deliver for multiple 10s of ms.
DJ
Instead of:
I prefer:
Post Edited (davejames) : 7/28/2009 3:34:24 AM GMT
I also have pulled apart my Maxwell boostcap 58F at 15v (6 x 350F "D cell supercaps") to see how the balancing works. They use 6 little active balancing circuits. However for what you want I suspect passive balancing with a resistor across each cell will be fine.
Also regarding the leakage, from what I've observed it seems to be dependent on many factors. Going from 100% to 80% charge happens much much quicker than 80% to 60%...
tubular
As you can see from the diagram attached with a constant value of R and C the capacitor will discharge much faster at the beginning. The reverse of this is true for charging. the cap will charge rapidly to 60% and then slow down as the voltage approach the same value. I plan to use a constant current source to keep the charging of caps relatively linear but the discharge will be like the diagram.
at 20F and 0.6ohm(20A) in 5ms the cap will discharge to 7.9V I then need to try and recharge back to full before the next shot. of course that is worst case scenario. I will try to keep timing as far as possible apart to minimize strain the customer truly has the final say.
A second way of calculating would be from an energy standpoint, each "small" supercap would store .5 * .9 * 4.5^2 or about 9 joules, 27J total for the 3. Your load is about 240 watts (20A*20A*0.6 ohms), which for 0.005 seconds is 1.2 J
What are the ematch characteristics like? I assume you need a strike voltage hence the need for multiple caps rather than straight I^2*R current...
The leakage point I was trying to allude to is that it doesn't seem to follow an exponential decay like everything else. Starting from rated 4.5 volts it drops the first volt within a matter of hours, but dropping the second volt takes days. The initial leakage rate is higher than the datasheet would indicate, then perhaps things start to stabilise.
tubular
