EEPROMs & more....
I was wondering whether this·would work as an EEPROM for the prop...· I didn't know whether there was a limit to the external memory, like in the case of the stamp modules...
Also, where it says the memory organization (in the given link, 128k x 8) does that mean that there is 1M memory available for use, or 128k?· I have a few 2k x 8 SRAMs, so they would technically be 16k?
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Thanks.
The 24C1025 begins a new set of daisy chaining. I haven't looked closely at it's specs to see if it will work.
128K x 8 means 128KBytes or 1024Kbits (=1Mbits). I think you are confusing bytes and bits. Yes, your 2Kx8 SRAMs are 16Kbits or 2KBytes. Note the upper and lower case B.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
So, what "special software" is required to use more than the lower 32k?
Thanks.
The thing is, I'm making a propstick kit, so I wanted to be sure about an eeprom before I solder it down...
Thanks.
Thanks for the help.
