easy high voltage DC motor control?
I'm trying to find an easy way to control some motors in the 45V range but low current (<1amp).·Most motor controllers I've seen use
In the propeller object exchange, there are objects for the LMD18201 and the L298 chips.· The L298 is a lot cheaper but seems to require quite a few more external components (diodes, etc).· Even the LMD18201 requires quite a few resistors and caps.· I found the following products and was wondering if anyone has used them:
http://www.anykits.com/catalog/product_info.php?cPath=46_70&products_id=244
http://www.anykits.com/catalog/product_info.php?cPath=46_70&products_id=436
Both seem reasonably priced and have screw headers + .100 header so are perfect for my application for interfacing to the prop.· With the prop objects, I would assume I could interface very easily.·
What is the advantage of the L298 vs the LMD18201?· It seems the L298 costs around $3 and the LMD costs around $15.
I am nervous about the L298 anykit part because Solarbotics offers something similar: http://www.solarbotics.com/products/k_cmd/
However when you read the data sheet here: http://www.solarbotics.com/assets/datasheets/solarbotics_l298_compact_motor_driver_kit.pdf
It says 6 to 26V operation·because the 1n5818 diodes and the LM2937 limit the upper range.
I wonder if the any kits is able to take the full 50V.
Does anyone else know of something similar to the any kits/modules but available in the US?· It seems they are in the UK or India and shipping is expensive.
Thanks in advance.
Thanks in advance.
How many motors do you need to drive? If I remember correctly the l298 object on obex takes a cog per motor. If you are interested I have an object that will drive up to 8 motors with 1 cog.
en.wikipedia.org/wiki/H-bridge
Hope this helps.
Kevin
I want to use the motor in a PID loop with optical encoder. With the current PID and quad encoder objects, this seems very easy.
I've used stepper motors in the past but I'd like to move to DC servos instead.
Also, I'm not sure why all industrial applications always use a high voltage like 45V or 60V for small DC motors but hobby projects always use something 12V or 24V.
Eventually I'll just build the LMD18200 circuit into my finish design but I'm experimenting with my prop board + bread board so it is a big hassle when there are a lot of discrete components.
