The Propeller Robot Module is up!
The Propeller Robot Module is a robot control board with 8 servo I/O and 8 sensor/general purpose I/O. has been tested by me with 7 servos running at once without a problem (I do have 9 servo's but the other 2 are in use right now so I only tested it with 7). also has an on-board LCD and 3 buttons for UI.
PRM (GadgetGangster)
Top view:
Bottom view (Propeller side)
I/O Pins:
Let me know what you think!
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
http://gadgetgangster.com/find-a-project/56?projectnum=171
Top view:
I/O Pins:
Brandon C.
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Gadget Gangster - Share your Electronic Projects
Brandon C.
So, what does the lcd display...?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Thanks, I got better after ruining my other BossBoard. I think I learned from my mistakes ...
the LCD displays information when debugging. e.g. you want to display the status of a sensor or the position of a servo. or you can just write whatever you want!
Brandon C.
Just putting in my 10 bits.
Doug
What happened to pin 17 on your Propeller??
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
my propeller has been through allot. lets put it that way.
Brandon C.
BTW, I have a few objects in the ObEx that might be useful: jm_debounce (for buttons), jm_lcd4_ez, and jm_servo8.
Thanks for the propeller objects! I already have an object for servo control and the LCD, but nothing for buttons yet. i'll be sure to check it out sometime.
Brandon C.
Are you going to post the code you're using with your project on G/G? The hardware is usually the easiest part -- for the project to be useful to others they'll need your firmware.
Brandon C.
