Cannot Connect to Propeller - Reset Pin Damaged?
Hello,
I have a Propeller Control Board RevA, and I can no longer·connect to it with the Propeller Tool v1.2.6. I am using a Prop Clip to try to connect. The board still seems to work with the currently loaded code (to control a Quadrover via RC control), but I cannot program it.
One thing I noticed with a voltmeter and oscilloscope was the RESn pin is not being pulled high like it should be - it is sitting at 0V. Would this indicate a damaged reset pin? Is it recoverable without replacing the chip? If not, I will attempt to remove the QFP package Propeller and replace it, though I would like to avoid this if possible.
If anyone has any thoughts, please share.
-Stephen
-Stephen
Au contraire, mon ami!
If it would be pulled high and the Prop wouldn't reset then you would be right.
Chances are, that the cabe is the cause or something in between the reset-pin and your connection.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Did you try another Prop Clip?
Or cable as Nick said, I have one or two go bad, (closing in car doors, etc.)
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
@ jazzed: The broken pullup is interesting. Based on that thought I tried·adding an external 10k pullup but unfortunately it did not help.
Any other thoughts? I think I will have to remove the propeller and replace it.
-Stephen
I've never heard of this as a mode of Prop failure, so I'd suspect the external circuitry....
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Have you tried checking RESn resistance to VSS/VDD? My PropProto board resistance is practically infinite to both.
--Steve
I just checked the resistance, and between Vss and RES, there is only 5.1K resistance, while between Vdd and RES there is also only 5.1K resistance. This was measured in several places.
-Stephen
I had the first prop plug for almost a year now...and it finally died, I will have a memorial service. You all are invited.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
How hard would it be to disconnect the propeller RESn pin? Is anything at all connected to the Propeller besides EEPROM and crystal ?
--Steve
The prop clip is showing near infinite resistance between all pins when it is unpowered, and when the prop clip is attached to the board, the resistance between Vss and RES and Vdd and RES is still 5.1K each. This is the same regardless of which direction the test leads are attached. Note that this is when the prop clip is unpowered/not attached to a computer.
When the prop clip IS attached to both a USB port and the board, the resistances get weird, changing depending on test lead polarity etc.
Note the board is unpowered at all times.
I also tried using another programmer to no avail. It was a SparkFun Electronics FT232R Breakout board modified with a resistor-capacitor-transistor in the same fashion a prop clip/plug is setup.
Is there anything else I should check/measure?
scdwyer, I'm afraid you have a problem that needs assistance from Parallax tech-support. They're good folks and should be able to help you one way or another.
--Steve
