(Un) precision 4.096 vrefs
I bought a few mchip 4.096 vrefs a while back, and installed them in my project. I decided to check them for accuracy, all of them are a bit off, as in one of them reads 4.122mv per my fluke 179. I suppose this is within specs, but it sure seems like I could do better. Anyone else found a good one?
I can recommend the LT1790-4.096, which comes in 0.1% or 0.05% accuracy grades. SOT23-6 package.
Tracy Allen
www.emesystems.com
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
The mcp1541 datasheet gives them 1%, so they are in specs.
I had just naively assumed that a precision reference was precision, and 1% hardly deserves to be labeled precision.
Think of it this way. I can bend a half inch pipe into a square in a minute if you don't care that the ends line up perfectly. If you want it to be a perfect square to the mm I will need to do some precision measurements and tweek my bends to get them perfect. May take half hour.
At least you learned a valuable life lesson. Read the datasheet and look for the infomation that is important to you(I.E. error factor)
