Calculating "Day Of The Week" from a date
Hello All,
I did a search and could not find any CODE on this forum. Does anyone know of any PBASIC code (BS2xx) that can do this? I've down loaded the Zeller's info from Google and working on my own. Thanks.
I'll search Google for some BASIC Code.
thanks again
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks again
hmlittle59
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
should be accurate to 2099
Thanks to all that replied, I'm already using the DS1302 and wanted to CODE it in. I looked in the Editor Help file and found the (//) command for Modulus. I'll be using the examples and figure it out...Thanks again
Hmlittle59
hmlittle59
'mn is 1..12
'yr is >= 1900
IF mn < 3 then· 'Jan & Feb = 13 & 14 preceding year
· mn = mn + 12
· yr = yr - 1
ENDIF
· weekday = (dy + 2*mn + (3*(mn+1)/5) + yr + (yr/4) - (yr/100) + (yr/400) + 1) // 7· '0=sunday
regards peter
The DS1302 already keeps track of the day of the week. Was there something outside of that you were trying to do?
Chris Savage
Parallax Engineering
I just wanted to learn to do it within my program without knowing?
Thanks Peter and to All
hmlittle59
Post Edited (hmlittle59) : 7/18/2009 8:34:58 PM GMT
Chris Savage
RTC chips do keep a cyclic count of 7 days, but you have to initialize it to the day of week scheme you want linked to the calendar day.
Tracy Allen
www.emesystems.com
I tried this code and I seem to be having some problems getting it to work correctly, could you help me get it working please?
thanks to all that can help
hmlittle59
Chris Savage
