Sharing the fbPin on Sigma Delta ADC measurements.
W9GFO
Is it possible to share the fbPin for multiple ADCs - so long as the measurements are not taken simultaneously?
RIch H
RIch H
You 'could' by just changing the reference to the input pin, but what's going to happen is that the 'other' unused pins that are still connected are going to affect your readings. You could I guess use an analog switch of some kind to externally multiplex the fbPin in conjunction with the interested input, but unless you have more than 4 sensors you don't really gain anything in the way of an I/O advantage. With multiple ADC inputs I would go with a multi channel ADC in this case.
You should check out these new high speed, 2.7V to 5.5V ADC's that we just started to carry at Parallax...
2-Channel 12-Bit A/D Converter with SPI Serial Interface - $3.47
4-Channel 12-Bit A/D Converter with SPI Serial Interface - $4.73
8-Channel 12-Bit A/D Converter with SPI Serial Interface - $5.22
Beau Schwabe
IC Layout Engineer
ErNa
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
