converting a 12volt ALTERNATOR to 24volt----BS2project
Hello All
I'm looking at converting a 12volt alternator over to 24volts. I can do this with some old school circuits,I was wondering if there was any modern ways to do this, And do it easily?
The ALTERNATOR RPM will be at least 3600rpm continuous
the LOAD will average 400 watts with sort term peaks of 1500watts (no more than 300mSecs)
Will use two 12volt 880 CCA/hr batteries in series.
the Load is two 600watt 24volt DC motors
I have a 100amp Delco that I plan to modify to 24volts.
Any new ideas would be greatly app.
_______________$WMc%_____________
The Truth is out there············································ BoogerWoods, FL. USA
Post Edited ($WMc%) : 7/19/2009 11:23:08 PM GMT
I really don't have room for two ALT.s and inverters would run the cost up.
I have thought of modifying this circuit that I have for 12volt alternators. I just thought someone would have a more modern Idea.
_Thanks Anyway______$WMc%_______
-dan
If it is a problem you could always remove them and use external diodes.
PS - I believe trucks (tractor trailer) may use 24V alternators.
I called a couple of junk yards and a used 24 ALT. is expensive.
I over looked the possible voltage limits on the 12volt ALT. Rect.Diodes, Thanks for pointing this out.
A 24volt ALT. maybe the way to go even if it is expensive, I need a lot of power for this project.
24volt ALT. seem to be pretty tough and most I've looked up have a 100% duty cycle.
_____Thanks Again________$WMc%________
Post Edited ($WMc%) : 7/19/2009 11:24:57 PM GMT
Thanks for the Idea. I remember seeing some 24volt ALT.s, They were military surplus, and they were cheap.Now if I can remember where I saw them!
The two 880cca/ahr Battery's I have are DEEP CYCLE. their not just regular car battery's
I thought of the inverter as well but My experiences with them follow Yours.
Thanks for the Reply, I'm getting closer and closer to My goal.
___Thanks Again_____$WMc%_____
Post Edited ($WMc%) : 7/19/2009 11:27:45 PM GMT
Post Edited (Prettybird) : 7/20/2009 12:25:30 AM GMT
