That unused RTCC pin
LoopyByteloose
Mostly I have seen schematics just ignoring an unused RTCC pin, but in the Nuts & Volts Article 153, it is tied to +5volts. So now, I am wondering if it should always be tied to +5, if it can be tied to +5 or ground, or if it doesn't really matter. Reading the SX28 PDF really doesn't offer any insight.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I do not usually come across schematics posted by knowledgeable users where RTCC is left floating.
To the best of my knowledge, the RTCC pin does not document whether it has internal weak pullups or not. And there is NO OUTPUT mode. Configuration is via the Option command, not the i/o port configuration registers.
In this schematic, it is pulled high. But there is no pullup resistor included. I am wondering if I should insert a 10K resistor for safety's sake. Due to being unused, pulling the RTCC to ground or to +5 seems arbitrary.
Post Edited (Loopy Byteloose) : 7/19/2009 7:22:32 PM GMT
Post Edit -- If you are using the RTCC input then you might want to set it high or low, as nec.,·because its status is "undefined" (as noted in the datasheet/s)·at power-on.
Post Edited (PJ Allen) : 7/19/2009 8:39:31 PM GMT
Right you are. I've rarely used the SX28 and don't have its pinout committed to memory. It looks like, with that one, you have two good choices!
Nearly all the Parallax general examples show nothing attached to any I/O or to the RTCC. There is clear discussion about the the regular I/O pins. But the RTCC pin seems entirely ignored in documents about construction.
Also I remember that someone (I think geunther) had a way to use the RTCC input to sense if a jumper was installed or not.
I think you changed the RTCC trigger direction or something....
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Robert
