Calculating "Day Of The Week" from a date
hmlittle59
Hello All,
I did a search and could not find any CODE on this forum. Does anyone know of any PBASIC code (BS2xx) that can do this? I've down loaded the Zeller's info from Google and working on my own. Thanks.
I'll search Google for some BASIC Code.
thanks again
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks again
hmlittle59
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
' Here is where we calculate the day of the week from the date ' (Thanks to Corrinda's "13 Steps to Mentalism"!) Dim whichDay, toChop whichDay = mid(diffYear,3,2) + int((mid(diffYear,3,2)) / 4) + monthCode + thisDate toChop = int(whichDay / 7) chopFrom = whichDay / 7 rawDay = (chopFrom - toChop) * 7 roundDay = Cint(rawDay) whichDay = roundDay - 3 ' -3 = Century Code until 2099 for comp... if diffMonth < 3 then whichDay = whichDay - leapYear ' Fudge Factor- why dates don't line up? if whichDay < 0 then whichDay = whichDay + 7 if whichDay = 0 then whichDay = "Saturday" elseif whichDay = 1 then whichDay = "Sunday" elseif whichDay = 2 then whichDay = "Monday" elseif whichDay = 3 then whichDay = "Tuesday" elseif whichDay = 4 then whichDay = "Wednesday" elseif whichDay = 5 then whichDay = "Thursday" elseif whichDay = 6 then whichDay = "Friday" end ifshould be accurate to 2099
DAT MTable long 0, 2678400,5097600,7776000,10368000,13046400,15638400,18316800,20995200,23587200,26265600,28857600 PUB datetonum(year,month,day,hour,minute,sec) | time 'year 2 digits, month 0-11, day 0-30, hour 0-23, min 0-59, sec 0-59 time:=31536000*year+86400*(year/4)+Long[noparse][[/noparse]@MTable][noparse][[/noparse]month]+86400*day+hour*3600+minute*60+sec if (year//4) & (month>1) time+=86400 return time PUB dayofweek(num) | time 'sun=0, mon=1... time:=(6+(num/86400))//7 return time▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Thanks to all that replied, I'm already using the DS1302 and wanted to CODE it in. I looked in the Editor Help file and found the (//) command for Modulus. I'll be using the examples and figure it out...Thanks again
Hmlittle59
hmlittle59
'mn is 1..12
'yr is >= 1900
IF mn < 3 then· 'Jan & Feb = 13 & 14 preceding year
· mn = mn + 12
· yr = yr - 1
ENDIF
· weekday = (dy + 2*mn + (3*(mn+1)/5) + yr + (yr/4) - (yr/100) + (yr/400) + 1) // 7· '0=sunday
regards peter
The DS1302 already keeps track of the day of the week. Was there something outside of that you were trying to do?
Chris Savage
Parallax Engineering
I just wanted to learn to do it within my program without knowing?
Thanks Peter and to All
hmlittle59
Post Edited (hmlittle59) : 7/18/2009 8:34:58 PM GMT
Chris Savage
RTC chips do keep a cyclic count of 7 days, but you have to initialize it to the day of week scheme you want linked to the calendar day.
Tracy Allen
www.emesystems.com
I tried this code and I seem to be having some problems getting it to work correctly, could you help me get it working please?
thanks to all that can help
' {$STAMP BS2e} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- DOW VAR Byte Month VAR Byte Day VAR Byte Year VAR Word '*********************************************************************************** ' Set Default Month/Date/Year/Day/Time.. '*********************************************************************************** Day = 20 ' 01st....31st Month = 07 ' Jan..to..Dec Year = 09 ' 01...99 IF month < 3 THEN month = month + 12 year = year - 1 ENDIF DOW = (Day+2*month+(3*(month +1)/5)+year+(year/4)-(year/100)+(year/400) + 1) // 7 DEBUG "Date of Today ", DEC2 day ,CR DEBUG "Month of Year ", DEC2 Month,CR DEBUG "What's the Year ", DEC2 year ,CR DEBUG "Day of Week ", DEC2 DOW ,CR▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
hmlittle59
Chris Savage
