TV (composite video) - Anyone use P15 (aural subcarrier in broadcast mode)? — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2009-07-17 22:54 in Propeller 1
In a design I require the use of the pin for a different purpose and was wondering if anyone is using this function with composite video?
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
  • BradCBradC Posts: 2,601
    edited 2009-07-17 07:45
    Cluso99 said...
    Absolutely. Every board I have that has a TV output is using the 4th pin for some other function. As long as it's not an output in the TV cog there is no interference anywhere else.
    Release the hounds!
  • ericballericball Posts: 774
    edited 2009-07-17 16:49
    This question has been asked previously: http://forums.parallax.com/showthread.php?p=810742
    P15 is used for:
    1. Aural subcarrier in broadcast mode.
    2. Chroma for S-Video output.
    3. My NTSC240H sprite driver uses all 4 pins to get brighter colors. However, the palette could be customized to only use 3 pins (or use 8 pins for 4+4 SVideo).
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    edited 2009-07-17 21:45
    ericball: Yes I had missed that thread. But, not many answered the question. The board I am doing is for general use plus some extras, and I want to use this pin. So this is why I am wanting to know how many use the pin for TV broadcast (or like you). As there is VGA, it could be used rewired to produce TV if necessary.
    edited 2009-07-17 22:22
    I've used it before and do provide the necessary DAC resistor for it on the boards I design. But, as of June here in the 'States, analog broadcast TV is gone, so the pin's long-term utility for an audio subcarrier is virtually nil, as far as I can tell.
  • hover1hover1 Posts: 1,929
    Ray,
    I understood the original question this morning. Just getting a chance to answer.
    I the 10-12 projects I have done so far NONE have had to use this pin. I have often thought of cutting the resistor off of the demo board to use it, but so far I have not had to. It would be a shame to hack a nice Parallax board. My boards, not a second thought tongue.gif
    Jim
    Cluso99 said...
