TV (composite video) - Anyone use P15 (aural subcarrier in broadcast mode)?
In a design I require the use of the pin for a different purpose and was wondering if anyone is using this function with composite video?
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
Absolutely. Every board I have that has a TV output is using the 4th pin for some other function. As long as it's not an output in the TV cog there is no interference anywhere else.
Release the hounds!
P15 is used for:
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
I understood the original question this morning. Just getting a chance to answer.
I the 10-12 projects I have done so far NONE have had to use this pin. I have often thought of cutting the resistor off of the demo board to use it, but so far I have not had to. It would be a shame to hack a nice Parallax board. My boards, not a second thought
Jim
