Codes for IR transmitter that was on the freebie table at UPEW
John Abshier
Using the IR Kit written by Bob Belleville.· I determined that it is a NEC compatible.· Codes are attached.
John Abshier
John Abshier
Or maybe there is a Propeller Object available ?
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
John Abshier
I'm going to give it a try tonight...
Experience level:
/Bamse
