PCB Etching with Muratic Acid, etc. Does it really work?
Oldbitcollector (Jeff)
Has anyone here done any PCB etching with muriatic acid, etc?
(As shown here: hackaday.com/2008/07/28/how-to-etch-a-single-sided-pcb/)
Questions: Does it work as indicated? How small can the traces be? Close enough surface mount?
OBC
New to the Propeller?
OBC
I would be curious also... I don't think HCl by itself will work, you need the Hydrogen Peroxide to initially get things going. The reason I say that ... as a kid I hollowed out a few pennies by scuffing the side of a penny and allowing pool acid to eat away at the inside portion of the penny. If it's just HCl, the copper is relatively inert.
Beau Schwabe
IC Layout Engineer
Do I need to neutralize it in some way to make it safe for dumping?
OBC
The whole idea from the instructables, was that you just kept re-using the "green" solution. Towards the end there was a suggestion to precipitate the copper out of the solution in addition to adding more HCL and Peroxide.
I believe that there was even the possibility of applying an electrolysis technique, leaving Copper on one of the electrodes. Not sure what you would use for the initial electrode however... Carbon maybe.
Beau Schwabe
IC Layout Engineer
2) I don't throw it away. (but if I did want to... I'm getting real curious if I could electroplate the copper out of the solution and just dilute the rest with water)
3) I get much better results with PCB etched this way versus FECL. (Mainly because I can see exactly when the etching has completed.)
It's very affordable...
Sample of RS485 board with .4mm to .8mm track widths
pwillard.com/?p=60
There's nothing like a new idea and a warm soldering iron.
Post Edited (pwillard) : 7/15/2009 3:53:16 PM GMT
I have had some trouble with a strong HCI solution washing the photoetch off. It works quite well otherwise.
All the acids containers I have are stored in a locked cabinet - the bottom of the cabinet is filled with about 10 big boxes of baking soda.·Yeap, if·a container·comes open,·the·spill isn't a problem - and I have·foaming evidence that somethings happening.
OBC: If you had to·neutralize the solution, I'd add *it* slowly to a large bucket of water (never water to acid!) and then dump in a few handfulls of baking soda until it didn't foam much, then a bit more water, a dash of baking soda again, more water, then all down the street drain or in the sewer. This is fine as long as the pH has gotten near 7 which is what the baking soda, after all, is doing.· (And if that still bugs anyone, realize that it's an old plumbers trick to pour muratic acid in the commode to clear it out - DON'T do this unless you really know what you're doing!)
- H
Post Edited (CounterRotatingProps) : 7/16/2009 1:56:12 AM GMT
The real concern though is... you can neutralize the acid... but can you deal with the copper. In these small quanties... is it not worth worrying about?
You know there's probably enough chromated copper arsenate (CCA) in people's yards from pressure treated wood that everyone using it may qualify for their own personal toxic waste dump. (Just kidding - or am I? Guess it depends on the EPA's definition of toxicity - government definitions are a moving target. [noparse]:)[/noparse]) Soooo ...
Spread it around the yard - it'll give the bugs something yumming to chew on :-P
- Howard
http://www.epa.gov/oppad001/reregistration/cca/
Will " chromated copper arsenate " work for chinchbugs ???
Derzban has become almost imposable to get anymore, And I'm tiered of making my own E.D.B. !
___________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
Now if somebody beside MG chemicals can make a tinning solution... I'd be in heaven doing my etching...
Sorry, what's "E.D.B." --- Electronic Destroyer of Bugs ?·· (First we had the carnivorous robot that fuels itself by eating flys - next we're gonna have a Prop-based bug zapping 'bot... mini-ping with mini-laser ... seeks out and destroys one bug at a time - LOL [noparse]:)[/noparse]
OK before we risk hijacking OBC's thread with that, I'm researching why the HCl + H202 work together when HCl alone really doesn't.
- H
Post Edited (CounterRotatingProps) : 7/17/2009 11:35:14 PM GMT
I've used Hydrochloric acid for years to clean rust off of antique metal parts (iron), I have found that the HCL reaction stops when all the "rust" is gone. Pull the sample out and its just plain gray metal, with only the rusty stuff removed.
I plain to run a series of test with different H2O2~HCL solutions to see what works best.
I'll post My findings here!
I think anything would better than FECL.
Be careful with HCL as it will attack silver,lower grade gold and platinum.
E.D.B. = Ethylene DiBromide, It kills chinchbugs on contact, and anything else it gets on.
_______________$WMc%_________
I never knew we'd be having a chemistry convo in a microcontroller forum. Good stuff though! [noparse]:D[/noparse]
"I never knew we'd be having a chemistry convo in a microcontroller forum." - lol
Better watch out or someone might come up with a semiconductor.
Beau Schwabe
IC Layout Engineer
sorry for the confusion, I was taking about etching copper. I have found that HCL does not attack copper or iron, but will attack copper oxide or iron oxide. Its the H2O2 that makes the HCL useful for copper etching.
I haven't seen an exact mixture of the two, What is it?
________________$WMc%______________
The H2O2 is drug store "topical" USP grade, about %3. (Anything over %7 is a tad dangerious, >%30 and you can start your own DIY rocket-fuel factory [noparse]:)[/noparse]
The mix is about 2 to 1 H2O2 to HCl.
- H
