Camcorder DCR-HC21 Sony
Has anyone tried to control basic stop/pause/record functions of a camcorder with a basic stamp?· How about this particular one.
I·have an underwater·housing·and some wires off the switches, that·seems straight forward, not sure on the camcorder side. ·
Mouser # 816-9092-05-10 takes only about 15mA at 5V
Mouser # 816-9117-05-11 uses only about 13mA at 5V
Some reed relays have a built-in diode. You'll have to supply your own 1N914 or equivalent if not. This is connected across the coil with the cathode (banded) end towards the I/O pin and anode towards ground. The relay turns on when the I/O pin is made high and turns off when the I/O is made low or an input.
Post Edited (Mike Green) : 7/16/2009 4:54:22 AM GMT
I can't help for about 3 weeks if your in a hurry sorry, If you can wait I could rig up a IR receiver and do some testing with a scope and get a few comands for you! I don't think it will Power on and off here is what my remote will do.
1··· Photo, Start / Stop
2··· Search forward and reverse
3··· Rew, Play and FF
4··· Pause, Stop, Slow
5··· Zero set memory, Display
6··· Zoom in/out
I am new·to the stamp and·signals so bear with me.·
now that I know what its called I think I will mess arround with some control also
http://peoples.slavutich.kiev.ua/lanc/index.html
http://www.boehmel.de/lanc.htm
Thank you. Best regards.
Remember, the Wikipedia is your friend!
