Experimenter card
Hey, I would like to put a 5x7 led matrix like this one : cgi.ebay.ca/5x7-dot-matrix-Red-LED-Display_W0QQitemZ220350280990QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item334de6751e&_trksid=p3286.m20.l1116
Someone has an idea how to drive it properly with the less io possible? Hope that it can fit in there [noparse]:)[/noparse]
With this type of display you have to multiplex the outputs, since not all the LEDs can be individually addressed at the same time.
I think you could do it in 8 I/O pins plus one ground pin if you have the appropriate "helper" chip. Here is a project that describes something similar:
http://www.best-microcontroller-projects.com/led-dot-matrix-display.html
Ross.
EDIT: Actually, on second thoughts I don't think you'd need any "helper" chips at all - I think the Prop should be able to do all the multiplexing fast enough to fool the eye.
Post Edited (RossH) : 7/16/2009 5:58:27 AM GMT
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: Forum
OnePinTVText driver: ObEx Forum
I don't think I can wire that on the experimenter card (it's just too big) so maybe I would have to make my own board,
but I never did any board layout before :S
Anyone already made an expansion card for the hydra?
http://www.lc-led.com/View/itemNumber/287
http://datasheets.maxim-ic.com/en/ds/MAX6953.pdf
