Fastest 16X16 multiply and divide
Is it correct to assume that the fastest 16x16 multiplication of two unkown variables, is the "school multiplication" method from desilvas assmbly tutorial? and similarly is the "school division" after that the fastest method for division?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I could test it with the PIC32 simulator. It should be quite easy to convert it into PASM.
Leon
It requires 4+16*# bits·in mulin1 (+8 for the CALL/RET) cycles.· Add 16 more cycles to automatically swap mulin1 & mulin2.
I've looked at Booth's multiplication algorithm·and I'm not sure it's any more efficient than a brute force method.· The inner loop is still done the same number of times.· The algorithm also requires a test against the 2 LSBs of a value, which doesn't map nicely to a single PASM instruction.· It also assumes 33 bit registers (for a 16x16 multiply), although it may be possible to cheat using the Carry bit.
One thing to pay attention to with all algorithms is the assumptions they are based on - "Booth used desk calculators that were faster at shifting than adding and created the algorithm to increase their speed".· Since PASM doesn't have that constraint, there may be better algorithms.·
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: Forum
OnePinTVText driver: ObEx Forum
Leon
Post Edited (Leon) : 7/16/2009 1:13:07 PM GMT
