Baudrate for the BS2PE
Tumbler
Hello,
I bought a 160x128 px glcd from sparkfun and want connect it to a BS2PE.
Datasheet here
When i take a look at this page, i can't find values for 115200 baud rate.
Is it possible to work with a 2PE?
It's possible to change the baud rates for the lcd, but i don't know how.
Can somebody help me to set it to 19200?
regards
Datasheet here
regards
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Cause i can't find something about it there
You can set the baud to 19200 from a PC terminal by sending the sequence $7C $07 $33 at a baud of 115200.
The serial connection on the display is 5v TTL so you will need a RS232 to TTL converter between the PC and your display to prevent damage to the display. You can use something like a MAX232 or the Parallax USB2SER http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/usb2ser/List/0/SortField/4/ProductID/32/Default.aspx
The data sheet tells you that to set the baud back to 115200 all you need do is send a character to the display within the first second of power up which also means you must give the display time to power up or you will lose your 19200 baud setting.
Jeff T.
The baudrate value for BS2pe at 19200 is 32.
Don't worry. Be happy
Thats why i have to change it to 19200
Does anybody a free RS232 software so i can change the baudrate?
I found this one ($40)
Jeff T.
The Lcd baud rate is programmed at 115200, i have to change it to 19200 to work with basic stamps.
I downloaded the demo version and it works great.
Now have to test it with some bs2 or javelin.
There's software readily available for free that will change the baud rate , depending on your needs there is free software that can be used for evaluating the display·.
Just need to know what you want·from the software.
Jeff T.
Well, just set the baudrate to another value [noparse]:)[/noparse]
The demo did the job, now i can connect it to a bs2 or javelin.
Good deal and good luck with the display.
Jeff T.
