Oxygen sensors?
xanatos
I'm looking for some small O2 and O3 sensors that can sense normal atmospheric concentration ranges. I know most cars have O2 sensors somewhere... not sure of their suitability for use in rocket telemetry. Suggestions/thoughts?
Thanks!
Dave X
Thanks!
Dave X
That is an interesting idea to use them on a rocket. There are a couple of concerns that come to mind though. One is weight. Most of the O2 sensors are about the size of a spark plug and may end up weighting too much for a model rocket (unless it is a very large rocket). The other is that I believe in order for the O2 sensor to read accurately they need to heat up first and don't start giving accurate vaules unless they are at exhaust temperatures. It was my understanding that some of the computers controlling the engine would just ignore the O2 sensor until it was warm enough to start producing valid data. Now this may have changed and perhaps some of the newer sensors don't need the heat and there may be some smaller sensors out there.
Robert
Dave
Dave Andreae
Parallax Tech Support·
http://www.vernier.com/probes/o2-bta.html
that may serve your purposes. Nothing for Ozone, though.
Note that the easiest way to use Vernier sensors with Stamps (and other micros) is to use an adapter of some sort. They sell simple breadboard adapters, which I have used:
http://www.vernier.com/accessories/access.html?bta-elv&btd-elv&template=basic.html
(the analog one should work with the O2 sensor)
but it looks like it might be easier to go with this cable:
http://www.vernier.com/diy/bb-bta.html
I used the analog breadboard adapter to bring the analog signals from light and temperature probes into a BS2pe MoBo, and everything worked as you'd hope.
I did fly their "Labpro" once, with an external high speed temperature probe. It's a pretty big, heavy·device to be flying inside a rocket, though. Building your own with Stamps or Propellers would save you the entire cost of the electronics in just a few flights by allowing you to use much smaller motors.
Robert - Dave is talking about a rocket that will be easily powerful enough to lift the kinds of things you're describing, though the warmup issue could well be a problem.
Google "amatuer rocketry", "high powered model rocketry" to learn more.· These is not the "toy" Estes type rockets.· See also: http://www.tripoli.org/·and http://www.nar.org/
John R.
Click here to see my Nomad Build Log
Thanks for the info on the Vernier sensor - it looks very much like what I have in mind and the price is do-able. I'm going to need a very good recovery beacon!!!
Dave
Dave
