Wierd Behavior of compiled assembled program.
In trying to chase down my problem with WKPND_B, I made some slight changes to the interupt program. 1 to set a bit in the timer routine every 1/100 of a second to use as a run bit for the tac and the second to the motor drive progarm to set the individual port bit instead of sending a whold byte to the port.· The first time I run the new version the program immediately goes to sleep.· When I run it under sxsim, I get a RETURNIW without an interupt error.· In backsteping the program, I get to a step where it is supposed to be·doing a jmp to A13. Instead it jmps to 13 which is in the middle of the ISR. Here is the listing of the Subroutine:
· 1151· =000001EB······ TAC_RESULT:····················· ;FUNC TAC_RESULT
· 1152·················
· 1153·················
· 1154·················································· ;····························· 'this measurement.
· 1155· 01EB· 0068······ ·CLR __WPARAM12_LSB············ ;····· __wparam12 =0··
· 1156· 01EC· 0069······· CLR __WPARAM12_MSB···········
· 1157·················
· 1158· 01ED· 072E············· SB····· Tdone····················· ;\·· SB····· Tdone
· 1159·················
· 1160 ·01EE· 0A13············· jmp···· txit····················· ;\··· jmp···· txit·· THIS JMP instruction is where it jmps to ISR
· 1161·················
· 1162· 01EF· 056E············· SETB··· TInhib·················· ;\···· SETB··· TInhib········· 'prevent interupt during
· 1163·················
· 1164 ·01F0· 001A······· BANK timing··················· ;····· Bank··· @timing
· 1165·················
· 1166· 01F1· 021C······· MOV __WPARAM34_LSB,Tac2_LSB··· ;····· __wparam34 = Tac2
······· 01F2· 002A
· 1167· 01F3· 021D······· MOV __WPARAM34_MSB,Tac2_MSB··
······· 01F4· 002B
· 1168·················
· 1169· 01F5· 0216······· MOV __WPARAM12_LSB,TacTime_LSB ;····· __wparam12 = TacTime
······· 01F6· 0028
· 1170· 01F7· 0217······· MOV __WPARAM12_MSB,TacTime_MSB
······· 01F8· 0029
· 1171·················
· 1172 ·01F9· 0217······· CJB Tac2_MSB,TacTime_MSB,@__ELSE_2 ;· if Tac2 > TacTime Then
······· 01FA· 009D 0703 0011 0A0D
· 1173· 01FE· 0743······· JNZ @$+8·····················
······· 01FF· 0011 0A06
· 1174· 0201· 021C······· CJBE Tac2_LSB,TacTime_LSB,@__ELSE_2
······· 0202· 0096 0603 0011 0A0D
· 1175·················
· 1176· 0206· 0C00······· ADD __WPARAM12_LSB,#$6000 & 255 ;······ __wparam12 = __wparam12 + $6000
······· 0207· 01E8
· 1177· 0208· 0C00······· MOV W,#$6000 << 8············
****** C:\Documents and Settings\Jim the boss\My Documents\sx documents\Atactest1.SRC(1177) Line 1177, Warning 37, Pass 2: Literal truncated to 8 bits
· 1178· 0209· 0603······· SNC··························
· 1179· 020A· 0C01······· MOV W,#($6000 << 8)+1········
****** C:\Documents and Settings\Jim the boss\My Documents\sx documents\Atactest1.SRC(1179) Line 1179, Warning 37, Pass 2: Literal truncated to 8 bits
· 1180· 020B· 0743······· SZ···························
· 1181· 020C· 01E9······· ADD __WPARAM12_MSB,W·········
· 1182·················
· 1183· =0000020D······ __ELSE_2:······················· ;····· Endif
· 1184· =0000020D······ __ENDIF_2:·····················
· 1185·················
· 1186· 020D· 046E······· clrb TInhib··················· ;····· \clrb TInhib
· 1187·················
· 1188·················
· 1189·················································· ;'···· __wparam12 = tacTime· - Tac2
· 1190· 020E· 0C04······· MOV __PARAMCNT,#4············· ;····· __wparam12 = BCD_WORD_SUB __wparam12,__wparam34
······ ·020F· 002C
· 1191· 0210· 0010······· CALL @__BCD_WORD_SUB·········
······· 0211· 09A4
· 1192·················
· 1193·················································· ;'···· Tac0 = Tac1············ 'handled in isr
· 1194································ ··················;'···· Tac1 = Tac2
· 1195·················································· ;'···· Tac2 = TacTime
· 1196· 0212· 042E······· clrb TDone···················· ;····· \clrb TDone············ 'wait for new info
· 1197·················
· 1198· ················
· 1199· =00000213······ Txit:··························· ;Txit:
· 1200·················
· 1201·················
· 1202·················································· ;'Txit1:
· 1203· 0213· 0018······· BANK 0························ ;Bank 0
· 1204·················
· 1205·················
· 1206· 0214· 0208······· MOV tmpW1_LSB,__WPARAM12_LSB·· ;····· tmpW1 = __wparam12
······· 0215· 0030
· 1207· 0216· 0209······· MOV tmpW1_MSB,__WPARAM12_MSB·
······· 0217· 0031
· 1208··············· ··
· 1209· 0218· 0210······· MOV __PARAM1,tmpW1_LSB········ ;RETURN tmpW1
······· 0219· 0028
· 1210· 021A· 0211······· MOV __PARAM2,tmpW1_MSB·······
······· 021B· 0029
· 1211· 021C· 000D······· RETP·······
I will get rid of the warning by changing the instruction from add $6000 to __wparam12 to ad $60 to __param2.
Obviously I don't want the program to jmp into the 13th line of the ISR, only to move forward a fiew line to the end of the FUNC
here is the SXB code for the TAC
'Tac_Result function that returns a word that contains the lapse
'time from the last revolution of the wheel
·FUNC TAC_RESULT
· __wparam12 =0
·\ ·SB·Tdone
·\·jmp·txit
·\·SETB·TInhib··'prevent interupt during this measurement.
··Bank·@timing
··__wparam34 = Tac2
··__wparam12 = TacTime
··if Tac2 > TacTime Then
··· __wparam12 = __wparam12 + $6000 'seconds have rolled over
··Endif
··\clrb TInhib
··__wparam12 = BCD_WORD_SUB __wparam12,__wparam34
·'·Tac0 = Tac1··'handled in isr
·'·Tac1 = Tac2
·'·Tac2 = TacTime
·\clrb TDone··'wait for new info
·Txit:
·'Txit1:
·Bank 0
··tmpW1 = __wparam12
·RETURN tmpW1
·ENDFUNC
Any Ideas why the unsual jmp is happening?
······· 01F2· 002A
······· 01F4· 002B
······· 01F6· 0028
······· 01F8· 0029
······· 0207· 01E8
······ ·020F· 002C
······· 0211· 09A4
······· 0215· 0030
······· 0217· 0031
······· 0219· 0028
······· 021B· 0029
·FUNC TAC_RESULT
· __wparam12 =0
·\ ·SB·Tdone
·\·jmp·txit
··Bank·@timing
··__wparam34 = Tac2
··Endif
··\clrb TInhib
·'·Tac1 = Tac2
·'·Tac2 = TacTime
·Txit:
·'Txit1:
·Bank 0
·RETURN tmpW1
·ENDFUNC
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
RS_JIM
RS_JIM
