Need Feedback on first Prototype board
Attached is my first PCB design ever. I need some feedback on the layout. Some of the routing is manual, some is auto, I am sure it can be better, but I would like some feedback before I send it out. I have been working on this on and off for about 5 months and I think this is ready for fab. I removed the GND planes so the board layout is easier to see.
Also, I have done some research and this PCB is 4 x4 so from Gold Phoenix for 99 bucks I can get 6 made. Has anyone else here used gold phoenix?
Greg
Greg
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
Always route critical nets like power and clocks first. Then start routing the remaining nets, shortest ones first. Don't use the autorouter!
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Firstly, congratulations on your first pcb
I'm worried about the two Vss / Gnd pins of the Prop coming from two very different paths. Best to cross link the Vss and Vdd at the prop with chunky 50 mil traces.
Are the AL1-3 relays? Could they be spun 180 degrees to maintain an isolation gap and shorten the tracks?
Haven't used GP yet, will be interested to hear your experience
tubular
There are other parts that would help if rotated. C1, C3 for example.
Placement seems to need some more improvement. And then re-route from scratch.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
@Tubular The VDD is connected VSS was but I removed the GND Plane so it was disconnected.
I moved some things around and rerouted some things and now there are no vias. So version 2 is now attached, let me know if it is any better.
Greg
Post Edited (Greg LaPolla) : 7/12/2009 12:52:16 AM GMT
That would have been me
Here's the link to the thread:
http://forums.parallax.com/showthread.php?p=816947
Russ.
Some of the power rails alternate what side of the board they are on despite not crossing any tracks. In my opinion it would be better to keep them on the same side - makes it easier to trace by eye when servicing etc. Because you have so much space why not make them wider?
The three base drive resistors under the prop - do you really want them there when you have so much room nearby (moving the prop powered logo somewhere else perhaps)?
That's OK, Cluso... I'll try to choke back my disappointment
You might also want to post a view with the ground plane intact so that people can look for errors on that.
have fun,
Mark
