Prop as USB Host ?
Saw a prop board a while back that had TWO usb connectors - dang if I can find it again :-(·
OK who's got it ?!
If I wasn't imagining this, it would be logical to assume·the board's config allows for the Prop to be a USB host. I just can't believe no one's tried that yet - so I must be looking in all the wrong places.
Any suggestions??
thanks
- H
BTW, I read through the USB 3.0 specs last night --- yes, aside from the wow-factor of 'superspeed', reading them was like eating rocks for desert
OK who's got it ?!
Any suggestions??
thanks
- H
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
If the prop had say the Vinculum·VNC1L-1A·USB Host controller (Parallax Item# 604-00051), which, according to info blurb here:
"not only handles the USB Host Interface and data transfer functions but owing to the inbuilt 8/32-bit MCU and embedded Flash memory the VNC1L-1A encapsulates the USB device classes as well"
Then the prop could Host, right?
Thanks for the link Steve, Brad's always doing somethin' cool...
Leon
--Steve
Has anyone attempted this yet?
> There is enough C source for the one library I looked at to choke Propeller memory several times.
I was wondering about that. Perhaps if it only supported a select few devices? I'm thinking about this generally as the 3.0 spec supports a host-to-host mode, using a cross-over cable. The lesser specs don't have that. Makes for some interesting possibilities. Oh well, maybe it'll take one of the Prop's bigger brothers to host - or maybe this is just wishful thinking ...
cheers
- Howard
