PC Board etchant, reuse, how many sq. in. before spent?
xanatos
Quick question for those of you who use Ferric Chloride etchant - how many square inches would you say you get to a given volume of etchant before the etch time is significantly increased, ie., the batch is spent?· Assuming standard 1 oz copper clad boards.
Also - anyone doing anything to successfully reclaim/reuse/revitalize the etch?· I try to be as environmentally friendly as can be everywhere else, but I really feel like I'm missing the mark on this particular item!
Dave
Dave
You can extend the life with hydrogen peroxide and hydrochloric acid. The copper dissolved in it will become cupric chloride, which is a good etchant.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Ferric chloride solution is a pain to use,Beside being expensive. It needs to be warmed up and stains every thing it gets on.
__ManyThanks________$WMc%______
The Truth is out there············································ BoogerWoods, FL. USA
I just can't figure out how to use copper pour in Eagle. !
www.fd.com.my
www.mercedes.com.my
www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
The icon for coper pour is the polygon tool. After putting down rename to vss or whatever net you want to use.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Good stuff folks - thanks very much!
Dave
I learned this from GOOTEE years ago and love it. It's the only way to etch for me now. I really like seeing what I'm doing, BUT!!!! do it outdoors and have some form of mask over your nose and mouth. Your lungs do NOT like breathing HCL.
I buy LONG woodstick cotton swabs... the kind used for electronic equipment cleaning... not ears and disposable rubber gloves. The cotton swabs are used to agitate the mixture close to the copper regularly during the etching process. No need for heat or bubbles like with ferric chloride.
If you spill it... (god forbid)... it leaves no stains (unlike permanent staining FECL) but it WILL dissolve concrete so flush with lots of water.
www.fullnet.com/~tomg/gooteepc.htm
There's nothing like a new idea and a warm soldering iron.
Leon
Mine are done in 5... maybe 10 tops.
Leon
