NEC Versa 2200C
Does anyone know the pinout of the power connector on the NEC Versa 2200C (see attached diagram), or know where I can get a service manual for it?
I suspect the 2 bottom pins are 19V in, but I would like to be sure before I power it up.
Any info would be greatly appreciated.
Pin 1---Not Defined
Pin 2---19V
Pin 3---Ground
And check here for other docs:
support.necam.com/mobilesolutions/hardware/notebooks/2200/2200man.ASP
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Post Edited (WBA Consulting) : 7/9/2009 5:52:29 PM GMT
