Faster PASM code, is it possible? — Parallax Forums
Bobb FwedBobb Fwed Posts: 1,119
edited 2009-07-10 23:55 in Propeller 1
I have this code with simply shifts a value out, then shifts a return value in. This is the fewest number of commands I could figure out to use, but I am still new to PASM, so I would expect some experienced PASM programmers may know some tricks. I recently saw forum thread about 4-clock per bit outputs and 8-clock per bit inputs (but that was using the CTRs). I don't need quite that fast, but I am still looking at 5 instructions per bit output and output. Maybe there is some way to prep the value so I can shift in or out faster. Any help would be nice.
''*  MCP 3008 ADC Frequency Reader v1.0  *
''*  Author: Brandon Nimon               *
''*  Created: 6 July, 2009               *
''* This PASM-driven object reads the values off of an MCP3008 analog to digital    *
''* converter (ADC) over the duration of one second. It mimics a Schmitt trigger,   *
''* only clocking cycles after the channel's value has gone from zero to above a    *
''* pre-specified value. Jitter can be easily reduced by requiring the "high" input *
''* to last for a certain number of ADC read cycles. The "high" value can also be   *
''* easily changed to fit the needs of the input and to widen the "Schmitt gap".    *
''* The program operates at about 1880 samples per megahertz the Propeller is       *
''* running at. Which theoretically equates to 940Hz input per megahertz (though    *
''* 620Hz or less would be safer assumption). Allowing for up to a 49.6KHz read at  *
''* 80MHz clock speed. The PASM code also returns, for use by the programmer, the   *
''* maximum and minimum ADC value achieved during the one second read time.         *
''* The program has only been tested at a maximum of 64MHz clock speed. It has also *
''* not been tested using the RX and TX pins from the ADC IC connected on the same  *
''* IO pin, but this method should work fine. It is possible at 3.3V, the MCP3008   *
''* may not be able to handle reads at above 107.2ksps. Testing was done on an      *
''* MCP3008 at 3.30V and achived over 120ksps without a problem.                    *
''* If precise voltage measurements are needed, be sure to read the MCP3008's       *
''* datasheet and note the skew of output values as the shift in/out speed is       *
''* increased or decreased.                                                         *
''* The PASM code could easily be altered to read the same values off of a MCP3208. *
''* The 10-bit shift would need to be changed to 12 and the empty shifts would      *
''* probably have to be increased as well. This can be done by altering the number  *
''* that comes after this: "MOV     bits_in, #" in the MAIN LOOP section, and       *
''* "MOV     emptyclk, #" in the SHIFT LSB IN AND IGNORE section.                   *
''* Some things that will affect how the program determines what a frequency is,    *
''* can be altered in the DETERMINE FREQUENCY section. Widening the "Schmitt gap"   *
''* or just requiring a higher voltage to consider "high" can be altered by         *
''* changing the number that comes after this: "CMP     val_out, #". Increasing     *
''* the value will decrease the number of false frequency clocks, but too high will *
''* eliminate clocks altogether. Waiting for a certain number of "high" cycles can  *
''* be changed by altering the number that comes after this: "CMP     track, #".    *
''* Resolution is reduced as the number of high cycles are increased, but it also   *
''* reduces the likelihood of false frequency clocks.                               *
''* Example wiring would be as follows:                                             *
''*               R1        *
''*     ADC─┳──┳──input device                                                  *
''*       C1 R2        *
''* R1: 10K (high impedence input is helpful, 10K should be the minimum)            *
''* R2: 100K (this effectively creates a voltage divider, but also drives input to  *
''*     zero volts when not in use)                                                 *
''* C1: 0.01µF (10000pF is the about the maximum you would want to use. The         *
''* capcitor reduces jitter or spikes but also reduces resolution).                 *
CON
  { ==[noparse][[/noparse] CLOCK SET ]== }
  _CLKMODE      = XTAL1 + PLL8X
  _XINFREQ      = 8_000_000                          ' 8MHz Crystal
  Vclk_p        = 24
  Vn_p          = 25
  Vo_p          = 26
  Vcs_p         = 27
OBJ
  DEBUG  : "FullDuplexSerial"
VAR
  LONG tx_pin                   ' 12 longs, DO NOT alter order!
  LONG rx_pin
  LONG ck_pin
  LONG cs_pin
  LONG bitcnt
  LONG channel
  LONG done
  LONG frequency
  LONG maxout
  LONG minout
  LONG count
  LONG duration
PUB Main
  DEBUG.start(31, 30, 0, 57600)
  waitcnt(clkfreq + cnt)
  DEBUG.tx($0D)
  repeat
    GET(Vo_p, Vn_p, Vclk_p, Vcs_p, 5, %11010)
PUB GET (DTPin, INPin, ClkPin, RSPin, bitcount, value)
  longfill(@done, 0, 4)
  longmove(@tx_pin, @DTPin, 6)
  duration := clkfreq
  cognew(@entry, @tx_pin)
  waitcnt(clkfreq - 1000 + cnt)
  REPEAT UNTIL (done)
  DEBUG.str(string("Cycles:     "))
  DEBUG.dec(count)
  DEBUG.tx($0D)
  DEBUG.str(string("Frequency:  "))
  DEBUG.dec(frequency)
  DEBUG.tx($0D)
  DEBUG.str(string("Max Value:  "))
  DEBUG.dec(maxout)
  DEBUG.tx($0D)
  DEBUG.str(string("Min Value:  "))
  DEBUG.dec(minout)
  DEBUG.tx($0D)
  RETURN frequency
DAT
                        ORG 0
'=====[noparse][[/noparse] START ]=========================================
entry
'-----[noparse][[/noparse] SETUP VALUES, PINS, AND TIMER ]-----------------
                        MOV     p1, PAR
                        RDLONG  p2, p1                  ' get data-out (TX) pin
                        MOV     DPin, #1
                        SHL     DPin, p2
                        ADD     p1, #4
                        RDLONG  p2, p1                  ' get data-in (RX) pin
                        MOV     NPin, #1
                        SHL     NPin, p2
                        ADD     p1, #4
                        RDLONG  p2, p1                  ' get clock (CLK) pin
                        MOV     CPin, #1
                        SHL     CPin, p2
                        ADD     p1, #4
                        RDLONG  p2, p1                  ' get reset (CS) pin
                        MOV     CSPin, #1
                        SHL     CSPin, p2
                        ADD     p1, #4
                        RDLONG  Bits, p1                ' get number of output bits
                        ADD     p1, #4
                        RDLONG  val, p1                 ' get output value
                        ADD     p1, #4
                        MOV     done_addr, p1           ' get "completed" mark address
                        ADD     p1, #4
                        MOV     freq_addr, p1             ' one second's worth of clocks
                        ADD     p1, #4
                        MOV     max_addr, p1            ' get max value address
                        ADD     p1, #4
                        MOV     min_addr, p1            ' get min value address
                        ADD     p1, #4
                        MOV     count_addr, p1          ' get min value address
                        ADD     p1, #4
                        RDLONG  sectime, p1             ' one second's worth of clocks
                        MOV     OUTA, #0                ' set all low
                        MOV     DIRA, #0                ' set all input
                        MOV     OUTA, CSPin             ' set CS pin high (inactive)
                        OR      DIRA, DPin              ' set pins we use to output
                        OR      DIRA, CPin              ' set pins we use to output
                        OR      DIRA, CSPin             ' set pins we use to output
                        MOV     Bits3, Bits             ' backup
                        MOV     Bits2, #32              ' set to reset value (32)
                        SUB     Bits2, Bits             ' determine number of shifts (difference of output bits and a long)
                        SHL     val, Bits2              ' shift value so first bit to output is at bit 31
                        MOV     val2, val               ' backup
                        MOV     val_max, #0             ' set maximum value to zero
                        MOV     val_min, #$1FF          ' set minimum value to $1FF (511)
                        SHL     val_min, #1             ' set minimum value to $3FE (1022)
                        ADD     val_min, #1             ' set minimum value to $3FF (1023)
                        MOV     freq, #0                ' clear any possible values
                        MOV     clkreadyh, #0           ' clear any possible values
                        MOV     idx, #0                 ' set index to 7 (to cycle through voltages)
                        MOV     strt, cnt                ' start timer
                        NEG     strt, strt               ' get negative (used in place of SUB later on)
'-----[noparse][[/noparse] MAIN LOOP ]-------------------------------------
bigloop
                        MOV     bits_in, #10            ' set to reset value (10)
                        MOV     Bits, Bits3             ' get backup
                        MOV     val, val2               ' get backup
                        ANDN    OUTA, CSPin             ' set CS pin low (active)
'-----[noparse][[/noparse] SHIFT COMMAND OUT ]-----------------------------
shift_out
                        SHL     val, #1         WC      ' shift output value and place bit 31 in C
                        MUXC    OUTA, DPin              ' set data pin to what value bit 31 was
                        OR      OUTA, CPin              ' start clock cycle
                        ANDN    OUTA, CPin              ' end clock cycle
                        DJNZ    Bits, #shift_out        ' cycle through the rest of the value
'-----[noparse][[/noparse] NULL BITS ]-------------------------------------
                        MOV     emptyclk, #2
:empty                                                  ' generate empty clocks to ditch unwanted bits
                        DJNZ    emptyclk, #:empty
'-----[noparse][[/noparse] SHIFT MSB VALUE IN ]----------------------------
                        MOV     val_out, #0             ' set to reset value (0)
shift_in
                        TEST    NPin, INA       WC      ' if data input pin is high
                        ADDX    val_out, val_out        ' add input pin value to output
                        DJNZ    bits_in, #shift_in      ' continue to end of input value
'-----[noparse][[/noparse] SHIFT LSB IN AND IGNORE ]-----------------------
                        MOV     emptyclk, #9
                        OR      OUTA, CSPin             ' set CS pin high (inactive)
'-----[noparse][[/noparse] DETERMINE MAX/MIN VALUE ]-----------------------
                        MIN     val_max, val_out        ' set val_max to whichever is highest
                        MAX     val_min, val_out        ' set val_min to whichever is lowest
'-----[noparse][[/noparse] DETERMINE FREQUENCY ]---------------------------
                        CMP     val_out, #4     WZ, WC  ' if current value is below or equal to "threshold value"
              IF_BE     JMP     #vbelow
vabove
                        CMP     track, #2       WZ, WC  ' if val_out has been above "threshold value" for this many times
              IF_AE     MOV     clkreadyh, #1           ' set value to 1 so when val_out goes below "threshold value" we can clock a Hz
              IF_AE     JMP     #move_on
                        ADD     track, #1
                        JMP     #move_on
vbelow
                        MOV     track, #0               ' clear tracking value
                        TJNZ    val_out, #move_on       ' don't execute the following unless current value is 0 ("low" -- this gap between "threshold value" and 0 allows for a bit of a schmitt effect)
                        CMP     clkreadyh, #0   WZ, WC
              IF_A      ADD     freq, #1                ' add a clock to Hz value
                        MOV     clkreadyh, #0           ' reset clock ready value
move_on
'-----[noparse][[/noparse] SETUP VARIABLES FOR NEXT LOOP ]-----------------
                        ADD     idx, #1
                        MOV     waitlen, cnt            ' get now
                        ADDS    waitlen, strt           ' difference of start and now
                        CMP     waitlen, sectime WZ, WC ' if below one second...do another loop
              IF_B      JMP     #bigloop                ' do it again!
'-----[noparse][[/noparse] END VALUE GATHERING ]---------------------------
                        WRLONG  idx, count_addr         ' number of loops to address
                        WRLONG  freq, freq_addr         ' frequency
                        WRLONG  val_max, max_addr       ' max voltage over the second-long sample
                        MOV     Bits2, #1
                        WRLONG  val_min, min_addr       ' min voltage over the second-long sample
                        COGID   val
                        WRLONG  Bits2, done_addr        ' write a non-zero value to done value
                        COGSTOP val
DPin                    RES                             ' tx
CPin                    RES                             ' clock
CSPin                   RES                             ' cs (reset)
NPin                    RES                             ' rx
sectime                 RES                             ' one second
waitlen                 RES                             ' tmp time
emptyclk                RES                             ' number of empty clocks to excecute
freq_addr               RES                             ' output address
max_addr                RES                             ' output address
min_addr                RES                             ' output address
done_addr               RES                             ' output address
count_addr              RES                             ' output address
freq                    RES                             ' frequency
clkreadyh               RES                             ' ready to add one to frequency
track                   RES                             ' store number of times above "threshold value"
strt                    RES                             ' watchdog start time
idx                     RES
Bits                    RES                             ' number of output bits
Bits2                   RES                             ' max number of bits available for output (32)
Bits3                   RES                             ' "backup" of Bits
bits_in                 RES                             ' number of value bits to shift in (10)
val                     RES                             ' output value (channel number plus %11000)
val2                    RES                             ' "backup" of val
val_out                 RES                             ' shifted in value
val_min                 RES                             ' minimum val_out
val_max                 RES                             ' maximum val_out
p1                      RES                             ' address pointer (for value/pin/address setup)
p2                      RES                             ' temperary value read from address
                        FIT 496
EDIT: Added full program in CODE section for reference.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Post Edited (Bobb Fwed) : 7/9/2009 11:02:25 PM GMT
  • rokickirokicki Posts: 1,000
    edited 2009-07-09 18:33
    Yes, there are tons of faster ways to do this.
    For simple examples, look at the fsrw object in the Obex.
    For more complicated examples, look at the existing fsrw repository on sourceforge, where we have some examples where we can shift a value out along with two clock transitions, all at one instruction per bit (20MHz at an 80MHz clock).
    For input, we have both two-instruction-per-bit and one-instruction-per-bit routines (the latter we are not yet confident in with respect to actual timing but the two-instruction-per-bit routines are solid).
    You look like you are doing SD I/O, so our code is probably something that should be interesting and relevant.
    In any case, for output, just dump the value in the PHSA register and shift that (setting the counter mode such that an output pin is always the high bit of the PHSA register). For input, TST/MUX and set one bit at a time. In both cases, unroll your loops.
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2009-07-09 18:47
    I am actually just writing a system to get a frequency from an ADC like the MCP3008/3208. So small output values (5 bits usually) and only 10- or 12-bit inputs. I am at about 1620 samples per second for each 1MHz the propeller is running at (theoretically 129.6K samples per second at 80MHz). I was hoping to make that faster, but at some point I will run into the limit of the ADC (of course slowing it down for the ADC at 3.3V is easy...but I want to be able to hit the limit of the ADC at 5V: 200K samples per second).
    edited 2009-07-09 22:38
    rokicki said...
    Well, using TEST/ADDX (not MUX) I was able to get the input down to 2 instructions per bit (plus CLK cycle and DJNZ).
    A couple other changes got me up to 1879 samples per megahert so a max of 150 ksps @ 80MHz. That is above the approximated limit of this ADC at 3.3V which is 107.6ksps. Of course, I've been testing it at over 120ksps at 3.3V without any problems.
    But I would love to get it up to the 227.2ksps which is the theoretical maximum of the ADC at 5.5V. I guess I will attempt the CTR use for the shifting out.
    edited 2009-07-09 22:46
    Yeah, CTR for shifting it out is easy.
    After that you want to consider generating your clock with a counter. Problem with that is your timing is
    pretty critical then; you need to make sure your clock edges are where you think they are with respect
    to your data generation and sampling.
    edited 2009-07-09 23:47
    Oops. Took a look at ADC so scratch that idea.
    Post Edited (kwinn) : 7/10/2009 12:28:54 AM GMT
  • KyeKye Posts: 2,200
    edited 2009-07-09 23:51
    RCR and RCl also acomplish the same thing as addx in what your're doing.
    So, for shifitng out with a counter. You would do something like: ... I'm not sure about this, I'm asking rokocki.
    Assuming the variable value is eight bits.
    shl value, #24
    mov frqa, #0
    mov phsa, value
    mov frqa, value
    And the counter would then just add that value to itself and shift it right out at 80 MHZ lets say.
    And then to slow it down you would divide that value into a bunch of parts so it takes longer for it to be shifted out right?
    Using powers of two would mean it would require very little time to do the divide also.
    Nyamekye,
    Post Edited (Kye) : 7/9/2009 11:58:13 PM GMT
    edited 2009-07-10 15:40
    Kye said...
    shl value, #24
    mov frqa, #0
    mov phsa, value
    mov frqa, value
    I've never been good with the CTRs...
    What CTR mode do you use for that code (above)? I think the FSRW object uses MOV CTRA, %00100 << 26 (or the equivalent).
    Then, how do you drive the serial clock pin with CTRB?
    After thinking about it the code I proposed won't work because the value changes when its shifted out.
    Um, you would use nco mode for low speed and pll for high speed.
    The idea is that you set the fraq register to zero and in pll mode or nco mode bit 32 is the output.
    So, you can just load the counter with the variable you want it to shift out, and then you just (shl phsa, #1) in a loop or unrooled loop and tha value is shifted out.
    Nyamekye,
