Help with uController Serial Keypad (demo program anyone?)
I just got the Serial Keypad from uController and could not get it to interface with the Propeller properly. I was just wondering what the serial commands sent out from it where, and whether or not anyone had a program written for it that could test if it's working.
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
The way I test them after assembly.....
If you own a Serial LCD, you could probably connect them directly to each other, of course making sure you have a common VSS.
The Serial KeyPad simply outputs the ASCII codes for the characters you press on the KeyPad at 9600 baud. If you supply the Keypad with 5V, the TX pin will output the serial data at 5V levels. If you supply the Keypad with 3.3V, the TX pin will output the serial data at 3.3V levels.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Brian
You need a TV display for output, but you could switch the output to something else pretty easily. If there is something else I can help with please ask.
www.trailofdestruction.com
I will try yours, GC, for if that works then I can copy that method. Moquito's did not work, parts-man's testing method worked, but I have tryed using FDS to receive it by Decimal, Hexadecimal, String, and byte and it will not
register if I pushed "1" or not in an if...then loop. I will try the new code, thanks.
Are you just running the demo code? Could there be anything else setting the pins for in/out?
Serial communications seem very susceptible to problems from a poor physical connection.
When I use a battery, it can have a low enough charge to drive the prop by itself, but get flaky when I start to attach sensors or chips to the same circuit.
My Robots
