Help with uController Serial Keypad (demo program anyone?)
I just got the Serial Keypad from uController and could not get it to interface with the Propeller properly. I was just wondering what the serial commands sent out from it where, and whether or not anyone had a program written for it that could test if it's working.
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
The way I test them after assembly.....
If you own a Serial LCD, you could probably connect them directly to each other, of course making sure you have a common VSS.
The Serial KeyPad simply outputs the ASCII codes for the characters you press on the KeyPad at 9600 baud. If you supply the Keypad with 5V, the TX pin will output the serial data at 5V levels. If you supply the Keypad with 3.3V, the TX pin will output the serial data at 3.3V levels.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Brian
You need a TV display for output, but you could switch the output to something else pretty easily. If there is something else I can help with please ask.
' Key Test for uController Serial Pad ' George Collins CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 TV_PIN = 20 KEY_PIN = 0 OBJ text : "tv_text" ser : "Simple_Serial" VAR BYTE mybyte PUB start 'start tv term with TV_PIN as first pin to tv plug text.start(TV_PIN) ' Tx of serial pad goes to Key Pin ser.init(KEY_PIN,-1,9600) repeat mybyte:=ser.rx waitcnt(cnt+1_000_000) text.out(mybyte) {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
www.trailofdestruction.com
I will try yours, GC, for if that works then I can copy that method. Moquito's did not work, parts-man's testing method worked, but I have tryed using FDS to receive it by Decimal, Hexadecimal, String, and byte and it will not
register if I pushed "1" or not in an if...then loop. I will try the new code, thanks.
Are you just running the demo code? Could there be anything else setting the pins for in/out?
Serial communications seem very susceptible to problems from a poor physical connection.
When I use a battery, it can have a low enough charge to drive the prop by itself, but get flaky when I start to attach sensors or chips to the same circuit.
My Robots
