Arrays and repeat loop
Hello there,
I'm fairly new to programming and totally new to microprocessors, but as a summer project from school I have started to get to know little bit about propeller.
Currently I am having trouples with arrays and repeat loops.
I just cant figure it out why this wont work. it reads the first value fine, but after that nothing. Is it some limitation on arrays that I cant use repeat loops to shorten my work, or have I misunderstood something?
Any help is greatly appreciated.
Post Edited (JacKal) : 7/8/2009 8:51:15 AM GMT
pub compare| i,j
repeat i from 0 to 63
j := place ' just a public method that returns values between 0 and 8191
if left_wall[noparse][[/noparse] i ] == j
return 1
else
return 0
Please update your post.
You talk about an array. Where is the array in your code?
pub compare| i,j repeat i from 0 to 63 j := place ' just a public method that returns values between 0 and 8191 if left_wall[noparse][[/noparse] i ] == j return 1 else return 0If this is what you wrote (including the indentation), I can't see a problem yet. Then you should provide the whole code.
Post Edited (MagIO2) : 7/8/2009 8:53:03 AM GMT
Actually, your code can be shortened to this and still does the same:
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
the problem is that what I am trying to shorten here is this:
left_wall[noparse][[/noparse] 0 ] == j
left_wall[noparse][[/noparse] 1 ] == j
left_wall[noparse][[/noparse] 2 ] == j
left_wall[noparse][[/noparse] 63 ] == j
to this:
the i variable should change between 0-63, but I can only read the first value [noparse][[/noparse] 0 ], after that it wont work. if i use the manual method above, it works as it should.
Yea, but then you should tell your compare what location you want to inspect.
Read: you have to pass the index you want to inspect to compare -> Compare needs a parameter.
Nick
YADRO
sorry if I'm not making much sense, but as English isn't my first language, I'm bit struggling to convey the meaning I'm after
pub find(what) | i repeat i from 0 to 63 if left_wall[noparse][[/noparse] i ] == what return 1 return 0Or maybe you want to know the index? Then you should return that.
Nick
YADRO
thank you !
Post Edited (JacKal) : 7/8/2009 10:11:38 AM GMT
