12v Flourescent Ballasts
william chan
I want to design my own 12v DC fluorescent light ballast.
There are a lot of cheap 12v ballasts in the market, but most are unreliable, inefficient, electrically noisy and some overheats.
Can I use the SX to create a sine wave to be transformed to about 600v so it can strike a fluorescent light tube without any heating delays?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
- H
Can I use 6v-0-6v : 240v 1A center tapped transformer to produce about 480v output.
Will it be sufficient voltage to strike a regular 4 foot 36 watt tube?
What is the best way to wire up the mosfets for best efficiency?
www.fd.com.my
www.mercedes.com.my
What I meant was running the SX at 50Mhz to produce a 1Khz sine wave.
Would a square wave be more efficient than a sine wave?
Will it cause standing wave patterns in the tube?
Could you give an example of how the SX and mosfets should be wired to the transformer?
Thanks.
"Aren't there cheap chips designed to do just this and be stable?"
There are, but the SX is readily available in my drawers and I can customize it to do other things like IR remote receiving.
www.fd.com.my
www.mercedes.com.my
