SERIN timeout and WAIT
I am running this command on a BS2p, but it never times out (never reaches the NoRadio tag):
Doesn't the timeout option work with the WAIT option?
/dev/null
SERIN pRFRx, N9600 + Inverted, 100, NoRadio, [noparse][[/noparse]WAIT("!!!!"), STR mystring\3]
/dev/null
Tracy Allen
www.emesystems.com
/dev/null
The Parallax receiver has a threshold. Any signal above that causes the data line to be high. Any signal below that causes the data line to be low. That's it. If your ambient noise level is too high, the data line will be high all the time. If the noise is intermittent, it will look like garbage characters and the SERIN will not time out. There is no squelch.
/dev/null
With the radio receiver you have, do you also control the transmitter? If so, you should know that the usual way to deal with noise is to transmit a preamble, something like,
SEROUT pRFTx, N9600 + Inverted, 2, [noparse][[/noparse]REP $55\4,"!!!!", STR mystring\3]
While there no squelch per se, nevertheless the threshold for the "data slicer" on the receiver end usually adapts to the signal level and finds a level where it is centered on what it "hears". The preamble or even a single pulse will silence the noise and condition the data slicer so that the receiver can properly slice the message. The preamble in the above is four %01010101 characters, paced 2 milliseconds apart. I think the docs for the Parallax xmtr/rcvr probably go into this issue.
Tracy Allen
www.emesystems.com
Yes I control the transmitter.
Thanks for tips, but I think there is just too much noise in my house to get this working, even with the preamble. I have a house full of wireless things and gadgets (I'm gonna die of EM raditaion, I know it!), and I live dead center in the city.
Also, I need bidirectional communication, and when you try that with the Parallax transmitters, it gets worse than with just one pair.
I've ordered a pair of BlueSMIRF, it's gonna be fun testing them. They are supposed to have a very clean signal, with range up to 100m, more than I need.
I've also ordered ZigBee modems, so I'm gonna try them out as well.
/dev/null
