State Machine
I am trying to setup a simple state machine which activates two pins at a time (to be used eventually in a switching circuit). For now I am hooking up pins 0 through 4 to LEDs on my PDB. I want them to scroll through, with speed determined by a delay, and direction, by a variable. Perhaps someone can point out where I'm going wrong. I currently see no output. Any help is much appreciated. Thanks!
(I eventually want this running on its own dedicated cog, but that's another issue i suppose)
var Long machine_delay byte direction pub run_machine(current_state) dira[noparse][[/noparse]0..4]~~ repeat if current_state > 5 current_state := 1 case direction 1: case current_state 1 : outa[noparse][[/noparse]0..4] := %11000 2 : outa[noparse][[/noparse]0..4] := %01100 3 : outa[noparse][[/noparse]0..4] := %00110 4 : outa[noparse][[/noparse]0..4] := %00011 5 : outa[noparse][[/noparse]0..4] := %10001 current_state++ waitcnt(machine_delay + cnt) 2: case current_state 1 : outa[noparse][[/noparse]0..4] := %11000 2 : outa[noparse][[/noparse]0..4] := %10001 3 : outa[noparse][[/noparse]0..4] := %00011 4 : outa[noparse][[/noparse]0..4] := %00110 5 : outa[noparse][[/noparse]0..4] := %01100 current_state++ waitcnt(machine_delay + cnt) pub get_direction return direction pub set_direction (dir) direction := dir pub get_delay return machine_delay pub set_delay(del) machine_delay := del
PUB MainLoop machine.set_delay(2_000_000) machine.set_direction(1) 'cognew(machine.run_machine(1), @Stack) machine.run_machine(1) waitcnt(300_000_000 + cnt) machine.set_direction(2)
You have to indent the whole stuff inside the repeat, otherwise your program ends faster than you can see the LED blink.
PS: Ok ... you won ;o)
BTW:
This is not a state-machine. State-machines have states and events (or transitions).
In your case, you wouldn't increment the state (state++), but send an event "forward" or "backward". The current state will then decide what the next state will be.
<http://en.wikipedia.org/wiki/Finite-state_machine>
Note that you have to generate events outside of the outer case. This might be polling a switch, or a timer generating events or ... whatever
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
"The FSM uses only entry actions, i.e., output depends only on the state."
Technically this is a Mealy machine because of the directional operator, but its more easily thought of in one direction, as a Moore.
The only way I would really update my code to make it any more like your example (and this is trivial) is in each case "state" to change the value of current_state to the next number, instead of incrementing up.
Post Edited (mminasian) : 7/7/2009 7:42:51 PM GMT
It looks quite degenerated.
Seems as if you could use an array of patterns and move along it with incrementing/decrementing an index that wraps around at the ends. Would be more compact.
Nick
YADRO
HAPPY!?! haha
Perfect, but it looks soooo ugly.
I see a shifting pattern, this SHOUTS for a different solution. Look for ROL and ROR.
byte pattern = %11001100;
if forward
pattern<-= 1;
if backward
pattern->= 1;
Hope ROL and ROR works on bytes.
Nick
YADRO
Then it is a SHL / SHR
If you draw each pattern below the other (I didn't), it gets most obvious what has to be done.
Patterns! Patterns! Gang of three (bad book).
Nick
YADRO
11000
01100
00110
00011
10001
This should be a rotate, using shift yields the same result
You'll notice the minor difference after more than one pass on the round robbin.
Nick
YADRO
Like a 74595 that has the SerIN connectet to the SerOUT or not (register preloaded, of course).
Connected: ROL/ROR
Disconnected: SHL/SHR
Nick
YADRO
