remote sensor project
Hello All,
I am working on a project for a biology class and need to setup a remote motion sensor that basically records the time that motion was sent. I am still going through the basic parallax tutorials, but I'm trying to plan ahead on what I'm going to need as far as a circuit to setup. I've figured that there are two ways to do it. One way is to have RF transmitters on each of the motion sensors, and those send data back to the main parallax unit (hopefully I could do this without having a parallax microcontroller at each remote sensor). Also, I could use the USB memory stick data logger attached to the motion sensors, but I believe each datalogger requires a parallax unit directly connected to it. I am really trying to keep the cost down as I won't have a very high budget. Worst case scenario I can have cables running directly from the motion sensors to the parallax unit, but then I'll have issues with distances of cables, as my distances need to be between 10 to 15 meters. Also, this is in the field if I can do it without cables that would really be the best.
Any tips on how I should go about this project? What method is better, usb datalogger or RF transmitter?
Bryan
Bryan
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
if not, you may with the right unit, get 30 feet distance mounting them back to back you could get 50-60 feet and the stamp could be in the same box.
The motion sensors will actually be outside, and possibly obstructed by shrubs or trees, therefore anything that requires line of site is probably a bad idea. (So I'm leaning towards wired.)
Larry, when you say those distances are you talking about these things being connected by wires, or RF transmitters? And I'm not sure by what you mean the stamp could be in same box? Do you mean at each sensor there would be a STAMP? Or you are saying wire them in series with STAMPS in the series to extend the range. If so, that's not necessary as I will be placing them in a circle around the STAMP so that each center is equidistant from the central unit.
Loopy, it seems like you are saying that it would be most effecient to have the motion sensor just send a signal back to the BS as soon as it picked up a signal, and then have it go into a buffer (since there will be multiple sensors). I wonder if there is any way to have a large buffer, or if I can set up the sensors so they somehow won't overload the BS buffer?
Bryan
Version two the serial port not only was used for download of info time,date,temp, but was hooked to a serial digital camera and took pictures,
And the new pir sensor was going to make this a lot smaller.
all the cameras switched to usb, usb·protocols were hard to come by back then, things just started moving too fast for me to keep up.
Are they going to stay in one place always, or will they need to be moved to other locations someday?
it was made with a pic chip but the testing was done using the BS2
Bryan
