Is this why prop II is waiting in the wings ? — Parallax Forums
mikestefoymikestefoy Posts: 84
edited 2009-07-07 16:41 in Propeller 1
quote :-
Taiwan Semiconductor Manufacturing Company, Ltd. (TWSE: 2330, NYSE: TSM) announced the foundry segment’s first functional 65-nanometer (nm) multi-time programmable (MTP) non-volatile memory (NVM) process technology. The technology incorporates process-qualified MTP IP blocks jointly developed with Virage Logic. The new technology is the first 2.5 volt MTP process, breaking the heretofore 3.3 volt baseline barrier. It eliminates the need for an external EEPROM currently in many systems applications, thereby reducing power, area and costs while increasing data security.
check out the press release
http://edageek.com/2009/07/02/mtp-nvm-technology/
    edited 2009-07-03 06:54
    No, it's got nothing to do with the Prop II. If memory serves me correctly, the Prop II will use a 1.8V process. It will include no internal non-volatile memory, except for masked ROM.
  • ImageCraftImageCraft Posts: 348
    edited 2009-07-03 07:10
    And I think the Propeller process is quite a bit north of 65nm....
    edited 2009-07-03 17:32
    mikestefoy,
    It has nothing to do with TSMC's 65nm process. ... until the multi-time programmable (MTP) non-volatile memory process matures, the IP will be very expensive.
    To put the processes in perspective...
    Prop I - 350nm process
    Prop II - 180nm process .... roughly 1/4th the size of Prop I
    65nm would nearly be 1/8th the size of a Prop II
    ...smaller is not always better, depending on what the chip is doing. At smaller processes you have much more gate leakage that must be dealt with. Moore's law does still apply, but getting this small, some of the physical properties that are well understood at the higher processes start to make a shift where quantum properties become·more dominant.
    Beau Schwabe
    IC Layout Engineer
  • BigFootBigFoot Posts: 259
    edited 2009-07-06 02:09
    I believe the prop II chip uses a .18 micron process. In contrast he prop I chip is 3.5 micron.
    edited 2009-07-06 02:24
    0.18 micron is 180nm (to be used for Prop II)
    0.35 micron is 350nm (currently in use for Prop II)
    See Beau's message
  • LeonLeon Posts: 7,620
    edited 2009-07-06 06:31
    FWIW, another well-known family of parallel processing chips uses the TSMC 90nm process, with the 65nm process being used for the new low-cost single core device.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 7/6/2009 6:38:38 AM GMT
    edited 2009-07-07 02:29
    As far as complexity goes, how many transistors do the Prop I & II chip's have ?
  • Nick MuellerNick Mueller Posts: 815
    Less than 1/4 of Propeller III (code name "Deltic engine").
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
