Strange behavior with math (Resolved) — Parallax Forums
Greg LaPollaGreg LaPolla Posts: 324
edited 2009-07-06 09:08 in Propeller 1
I may be missing something here but this has been driving me crazy for 2 days.
I have 2 variables timer_val and timer_ela. I can perform simple math functions (add and subtract) on them, however if I perform anything on them together I get strange results like:
lets say timer_val is 60 and timer_ela is 3
timer_rem := timer_val - timer_ela
timer_rem will be equal to 60, but should be 57.
timer_rem := timer_val -1
timer_rem will be equal to 59
timer_rem := timer_ela + 1
timer_rem will be 4.
All these variables are declared as type long, does anyone have any insight on this ?
Greg
Post Edited (Greg LaPolla) : 7/6/2009 12:18:19 AM GMT
  • AleAle Posts: 2,363
    edited 2009-07-05 17:46
    I do not believe you, post the code please, all of it (even how you get the values of the variables).
    Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-07-05 18:26
    Ale,
    That's a rather blunt appraisal, but I have to concur.
  • Greg LaPollaGreg LaPolla Posts: 324
    edited 2009-07-05 18:58
    The objects are attached.
    timer_val is obtained by calling Resistance method in RcResistance.spin
    timer_ela is obtained by calling the rdReg method in timer.spin using the TMR_MINS parameter
    here is the code to get the resistance:
    PUB Main
      repeat
        if ina[noparse][[/noparse]24] == 1
          timer_val := display.getTimer
          timer.reset
          display.setup
        timer_ela := timer.rdReg(timer#TMR_MINS)
        display.update (timer_rem)
        waitcnt(clkfreq  + cnt)
    PUB getTimer: R
      meter.Init(RC_PIN, HL_PIN, CAP_VAL, COR_FACTR)  ' Initialize RcResistance
      output.tx(output#CLS)
      repeat until ina[noparse][[/noparse]24] == 1                  ' Repeat loop
        R := meter.Resistance / 9                ' Get resistance
        waitcnt(clkfreq/10 + cnt)                ' Display refresh 10 Hz
        output.tx(output#HOME)
        output.Str(String("Timer = "))
        output.Str(num.decf(R,3))                 ' Update display
        output.tx(output#CLREOL)
    basically what this is is a 10K 10 turn pot that is used th set the value of timer_val. if you press a momentary switch it allows to take a reading from the pot then press it again to return to the timer.
    edited 2009-07-05 18:59
    Sorry if I was harsh :-(. No code would work if that was true and we have plenty of working code that uses such a statement, so the error has to be somewhere else, i.e. variable load or variable reading or in some assumption that does not have ground.
    edited 2009-07-05 19:03
    How do you know that timer_ela == 3? I don't see it being displayed anywhere.
    edited 2009-07-05 19:04
    timer_val seems to be initialized just when ina[noparse][[/noparse]24] == 1, what happens when that condition is not met ?
    Print the values of timer_val, timer_ela and timer_rem and you will find out how you get false results... then investigate the source.
    edited 2009-07-05 19:08
    I have done all that. I know that the values are all correct. The issue is that
    will always be equal to timer_val.
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-07-05 19:28
    Did you try it with a bigger stack for the timer-cog?
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
    edited 2009-07-05 19:30
    Very good suggestion Nick ! I always forget about the strage problems that a small stack can produce !
    edited 2009-07-05 19:37
    The timer object works as expected.
    if I set timer_rem := timer_ela
    The timer display on the screen will increment by 1 every minute
    if I set timer_rem := timer_val
    The timer display on the screen will show the reading from the pot.
    If I set timer_rem := timer_ela + 1
    The timer display on the screen will show the reading from the timer + 1
    if I set timer_rem := timer_val + 1
    The timer display on the screen will show the reading from the pot + 1
    Hence my problem that timer_rem := timer_val - timer_ela will always be equal to timer_val.
    edited 2009-07-05 20:04
    So the difference is 3 minutes?
    That sounds like an overroll in CNT.
    Nick
    YADRO
    edited 2009-07-05 20:09
    Forget about 3 it was just a for instance I set up.
    everything works as expected withe the proper results except for this line:
    no matter what timer_ela is this equation will always be equal to timer_val.
    edited 2009-07-05 20:18
    Did you try it with the stack?
    Did you try a print of the values directly before and after the assignment?
    Did you try so filler-vars to avaoid overwrites?
    Nick
    YADRO
    edited 2009-07-05 20:29
    Greg,
    Making sure your stack is big enough is a good idea. Otherwise, the value for one of your operands in the subtract is simply not what you think it is. Spin math is airtight. If the compiler/interpreter were making an error of the kind you supect, it would've been discovered and corrected long before now.
    One of the hardest lessons to learn when debugging is to search for what you did wrong, rather than convincing yourself that what you did was right. ("It should work!") After forty years of programming, I still have to check myself on this issue! smile.gif
    edited 2009-07-05 20:33
    > "It should work!"
    It's OK if you say that *before* letting run the program. But if it fails, the only allowable question is "what did I do wrong", and the only allowable statement is "I don't get it", or "I'm an idiot" (after you found the bug). smile.gif
    Nick
    YADRO
    edited 2009-07-05 20:40
    Hello Greg,
    please use the archive function of the propellertool to zip ALL lines of code that you were using
    you made several quick shots that didn't solved the problem.
    So it is time to do a careful analyse for EVERY DAMMED SINGLE line of code.
    we can go on guessing into the fog for weeks and month or take half a day to
    I repeat myself
    best regards
    Stefan
    edited 2009-07-05 20:51
    Phil,
    Your absolutely right after almost 30 years I still fall into that hole too!
    I have done as nick suggested looking at the values before and after and also trying filler vars, everything is correct.
    I really don't think the stack is the issue. I am not performing any calculations in the cog running timer.
    I even tried changing variable names to X, Y and Z just to make sure nothing was overwriting.
    Greg
    edited 2009-07-05 21:26
    Never make assumptions. Only verification helps.
    Do you think the variables are sorted alphabetically in RAM?
    Nick
    YADRO
    edited 2009-07-05 21:29
    Don't forget that the stack is used to pass method parameters and to hold local variables. If you have lots of parameters or the method calls are nested, you could easily get a stack overflow in Spin cogs that you've started from the top level.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-05 21:41
    Another approach:
    isolate the code into the smallest chunks that will run the code block in question - eliminate everything else. If the problem goes away... well, obviously add in code piece by piece. (The lazy way to check 'every damn line of code' [noparse];)[/noparse]
    - H
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-07-05 22:12
    A stack size of 12 is suspect. Could you confirm that you have tried a larger stack? Say 25?
    Can you add a serial port object, and serial.dec(timer_ela) ?? I suspect you will get a 0
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-07-05 22:24
    Greg said...everything works as expected withe the proper results except for this line:
    Then apparently timer_ela is 0 prior to the line.
    I'd say test that for sure, then find out why it became 0
    if you expected some other value.
    regards peter
    edited 2009-07-05 23:28
    I agree with Erik: a stack size of twelve longs is almost certainly too small.
    edited 2009-07-06 00:08
    I have finally identified a problem. I am still chasing it. My program outputs to PST right now so I hooked up an lcd to dump data real time. So tEla will increment as expected until I press the button and trigger ina[noparse][[/noparse]24] == 1. At this point tEla stops counting. until the prop is reset. So now I need to look into debuging the timer object, as it appears to be the culprit. Stay tuned!
    Greg
    edited 2009-07-06 00:17
    So I found the issue, I did not fully RTFM. after issuing a timer.reset, you have to issue a timer.run. nono.gif
    Sorry for granny-telling: The first thing you should have for µC-debugging is a serial connection on the µC and a terminal on the other end. As soon as you do have that, you have won. All else is simply a PITA to work with.
    Nick
    YADRO
