Eagle Help
I have been working with Eagle for a long time and love it. One thing I have not figure out how to do is make the solder mask cover a via. Does anyone know how to do this in either eagle or know a program that can do it in the gerber files?
If you have any questions on how to use Eagle feel free to ask.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
(I've only looked superficially at both so far)
(I dug around on ExpressPCB, but didn't see mention of the gerber format)
I'm still experimenting with which schematic<->board software to use... Diptrace is looks powerful, but it costs too much for me right now. Eagle seems pretty easy to use so far ... lot's of quirks that are really features [noparse]:)[/noparse]) Wish there were some low-cost CAD software too that does both mechanical and electronic like the old TurboCAD ... still hunting...
thanks
- H
Dip trace looks good but I do not have $700 and already purchased full eagle 4.1. And have all designs in it.
The freebee version doesn't allow me to select the net list type to export - can you do that on the one you have? (Not sure what the ExpressPCB expects for net list format, several are listed, but I hacked on it enough to see that I'd need to figure out its format. Are all net lists in a text format of some kind with different headers?)
[noparse][[/noparse]edit:·DOH! Express takes gerber files... problem solved... no more expressSCH/PCB for me !! ]
Post Edited (CounterRotatingProps) : 7/1/2009 11:45:29 PM GMT
I finally found a laser printer to print PC stencils (with toner).
I down loaded the freeware Eagle 5.4.0 a while back. Can this software print a stencil to etch a PC board?
If so I could use a little help getting started with Eagle
Thanks in advance
______________$WMc%___
The Truth is out there············································ BoogerWoods, FL. USA
1) load your board layout.
2) press ratsnest button bottom left 5 circles with lines between.
3) press 3 coloured icon in top left below the i
4) press none
5) turn on layers 1,17,18 for top or 16,17,18 for bottom
6) select file->print
7) select only black, and solid.
8) print
Are you aware of this? http://forums.eagletoolkit.com/ It is a conventional forum form of the cadsoft newsgroup.
What is the normal software that is used to create the PCB layout that Eagle will work with?
Thanks in advance for any help. Like I said, I'm just getting started with this software!
_____________$WMc%_________
I'm havening some trouble getting started with EAGLE 5.4.0. Is there a link I can download to help Me get started with EAGLE? Like a user Manuel or some other doc.s
I'm not looking for a gerber interpreter, Just a Manuel or guild to get started with EGALE from scratch. I have a valid freeware user license from CadSoft. I have never used any software like this before, And I really need some help getting started.
I want to start with the PIC16C57C with the Interpreter burnt in by Parallax
Any help would be great!
Thanks in advance
______$WMc%___________
look Here on spark fun, about half way down there is a series of tutorials on eagle. That should be enough to get you using eagle like a pro.
