Is this why prop II is waiting in the wings ?
quote :-
Taiwan Semiconductor Manufacturing Company, Ltd. (TWSE: 2330, NYSE: TSM) announced the foundry segment’s first functional 65-nanometer (nm) multi-time programmable (MTP) non-volatile memory (NVM) process technology. The technology incorporates process-qualified MTP IP blocks jointly developed with Virage Logic. The new technology is the first 2.5 volt MTP process, breaking the heretofore 3.3 volt baseline barrier. It eliminates the need for an external EEPROM currently in many systems applications, thereby reducing power, area and costs while increasing data security.
check out the press release
http://edageek.com/2009/07/02/mtp-nvm-technology/
It has nothing to do with TSMC's 65nm process. ... until the multi-time programmable (MTP) non-volatile memory process matures, the IP will be very expensive.
To put the processes in perspective...
Prop I - 350nm process
Prop II - 180nm process .... roughly 1/4th the size of Prop I
65nm would nearly be 1/8th the size of a Prop II
...smaller is not always better, depending on what the chip is doing. At smaller processes you have much more gate leakage that must be dealt with. Moore's law does still apply, but getting this small, some of the physical properties that are well understood at the higher processes start to make a shift where quantum properties become·more dominant.
Beau Schwabe
IC Layout Engineer
0.35 micron is 350nm (currently in use for Prop II)
See Beau's message
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 7/6/2009 6:38:38 AM GMT
Less than 1/4 of Propeller III (code name "Deltic engine").
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
