LED Light detector
Hi everyone, I am just getting back in to playing with SX/B (its been a few years.) I was playing around with making an LED light detector. So i have an led hooked between RB.1 and RB.2 with a resistor in series. Here is the code:
I have another LED connected to RB.7 that is supposed to turn on if the value of light is 0. Not seeming to work. I copied this from similar code i found from the basic stamp and it worked fine with my stamp. I just made a few changes for the SX and no go...
Here is the code i used as a base for the Stamp:
Thanks!
John G
'PWM.SXB DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX FREQ 4_000_000 led2 PIN RB.2 led1 PIN RB.1 led7 PIN RB.7 light VAR Word time CON 2000 'Code PROGRAM Start Start: led1 = 1 led2 = 0 DO OUTPUT led2 OUTPUT led1 RCTIME led1, 1, light IF light = 0 THEN led7 = 1 ELSE led7 = 0 ENDIF PAUSE time LOOP
'{$PBASIC 2.5} 'file:LED_Emitter_Detecter.bs2 'Clark Radcliffe 'Michigan State University 'July 30, 2007 'Requires an LED in series with a 220 Ohm resister 'between pin 1 and the LED connected to pin 2 'Declarations Pin2 PIN 2 Pin1 PIN 1 light VAR Word time CON 2000 'Code DEBUG "Start test...", CR DO DEBUG "LED is a detecter (LED off and charging)", CR Pin1 = 1 Pin2 = 0 PAUSE 10 RCTIME pin1, 1, light DEBUG "Light measured = ", DEC light, CR PAUSE time LOOP
Thanks!
John G
I don't see in your code where RB.7 is set as an output. It could be that the pin is set as an input.
-Benoit
Your Stamp code debugs out the value; for the SX, use WATCH and then run the program in DEBUG mode with your Key connected. Then try it out and see what values you get for various light intensities -- once you have a decent threshold number established, then you can have an LED turn on and off based on that threshold.
Then, shouldn't the loop turn the led back on (and maybe pause) to charge up the capacitance again?
Post Edited (Zoot) : 7/2/2009 1:26:56 AM GMT
That was it. Thanks! It works perfectly now.
John Gjonola
