Interfacing Stamp with External Memory
Hello experts,
I'm working on a project in which I collect data from an accelerometer for around 10 minutes to capture motion of my board. Therefore, I needed external EEPROM to store that data. I chose the 24LC256 memory chip and now I'm trying to interface it with the Stamp. (I'm using BS2e)
So I was wondering if anyone here has tried that kind of combination -- Stamp + an external memory chip -- and could possibly tell me if it's possible. I'm thinking about using the shiftin and shiftout commands as I did with a 12-bit AD converter. But what I was concerned about is that Stamp generates its own clock implicitly in those commands and whether it's gonna cause any incompatibility with the memory chip...
Has anyone done this before? Any feedback will be very much appreciated!
However, with that chip, you'll probably need to use the I2C commands instead of the shiftin/out commands. The 2 main protocols to communicate with eeproms are SPI (shiftin and shiftout, like the ADCs you're familiar with) and I2C. It looks like the chip you chose uses I2C. You can make it easier on yourself and get an SPI eeprom, or stick with the 24LC256 and use the I2C commands. Your pick.
Hope that helps...
Dave
One more question since this was brought up: I'm really a newbie in this field, so could you also explain to me which between SPI and I2C is better to use? And if it were you, which direction would you go with? I know I picked SPI because of my Stamp chip, but if I can choose without constraints, what should I go with? --- just curious.
Thanks a lot for your help!
SPI is a not very standardized at all protocol that requires three or four I/O lines. Some of these lines can be shared among devices, but you always need a select line that's unique to each device. There are all sorts of variations on this protocol with minimal commonality among devices. It's very fast though, often with devices that can accept up to a 20MHz clock (although the Stamps are much slower than that).
' {$STAMP BS2} ' {$PBASIC 2.5} SDA PIN 0 ' I2C Serial Data Line SCL PIN 1 ' I2C Serial Clock Line ChipAddr CON $A0 ' 24LC128 chip address EpromSize CON 16 ' e.g. 16K or 32K Ack CON 0 ' Acknowledge Bit temp VAR Byte ' Variable Used For Work i2cWork VAR Word ' Work Byte For I2C I/O i2cAck VAR Bit ' Ack Bit From Device start VAR Word leng VAR Word '# bytes to dump incr VAR Nib MemAddr VAR Word ' EEPROM memory address 0 to 16383 (16k) ' MemAddr = 16383 ' temp = 254 ' GOSUB Write_byte ' GOSUB Pippin leng =256 DO DEBUG CR, "Enter ChipAddr to dump, 0 to ", DEC (1024 * EpromSize) - leng + 15, ": " DEBUGIN DEC5 start start = (start/16)*16 MemAddr = start DEBUG CR DO DEBUG DEC5 MemAddr, " " FOR incr = 0 TO 15 ' Reading Section GOSUB Read_Byte DEBUG CRSRX, (incr * 3) + 7, HEX2 temp SELECT temp CASE < 32 DEBUG CRSRX, (incr * 2) + 60, "." CASE > 128 DEBUG CRSRX, (incr * 2) + 60, "." CASE 32 TO 127 DEBUG CRSRX, (incr * 2) + 60, temp ENDSELECT MemAddr = MemAddr + 1 NEXT DEBUG CR LOOP UNTIL (MemAddr >= (start + leng)) LOOP END Pippin: ' start=01023 start=02048 MemAddr = start temp = "P" GOSUB Write_byte MemAddr = MemAddr + 1 temp = "I" GOSUB Write_byte MemAddr = MemAddr + 1 temp = "P" GOSUB Write_byte MemAddr = MemAddr + 1 temp = "P" GOSUB Write_byte MemAddr = MemAddr + 1 temp = "I" GOSUB Write_byte MemAddr = MemAddr + 1 temp = "N" GOSUB Write_byte MemAddr = MemAddr + 1 MemAddr = start RETURN Clear: MemAddr = start temp = 0 Init: FOR incr = 0 TO 15 GOSUB Write_byte MemAddr = MemAddr + 1 NEXT IF MemAddr < start + 128 THEN GOTO Init ENDIF RETURN '------- I/O routines based on microcontroller type ----------- #SELECT $STAMP ' -----[noparse][[/noparse] BS2 Subroutines ]------------------------------------- #CASE BS2, BS2E, BS2SX Write_Byte: 'write byte in temp to MemAddr GOSUB I2C_Start GOSUB Control_Byte_Write GOSUB Addrs GOSUB Write_Data GOSUB I2C_Stop PAUSE 10 RETURN Read_Byte: 'read byte from MemAddr into temp GOSUB I2C_Start ' PAUSE 10 GOSUB Control_Byte_Write GOSUB Addrs GOSUB I2C_Start GOSUB Control_Byte_Read ' SHIFTIN SDA, SCL, LSBFIRST, [noparse][[/noparse]i2cwork\8] ' Send Byte To Device SHIFTIN SDA, SCL, LSBFIRST, [noparse][[/noparse]temp\8] ' Send Byte To Device GOSUB I2C_Stop RETURN I2C_Start: ' I2C Start Bit Sequence INPUT SDA INPUT SCL LOW SDA ' SDA --> Low While SCL High RETURN I2C_Stop: ' I2C Stop Bit Sequence LOW SDA INPUT SCL INPUT SDA ' SDA --> High While SCL High RETURN Addrs: ' I2C ChipAddr Byte Sequence i2cWork = MemAddr SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork.HIGHBYTE\8] ' Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork.LOWBYTE\8] ' Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit RETURN Control_Byte_Write: ' I2C Control Write Byte Sequence i2cWork = ChipAddr i2cWork.BIT0 = 0 ' Sets Unit To Write SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] ' Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit RETURN Control_Byte_Read: ' I2C Control Read Byte Sequence i2cWork = ChipAddr i2cWork.BIT0 = 1 ' Sets Device To Read SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] ' Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit RETURN Write_Data: ' I2C Write Byte Sequence i2cWork = temp SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] 'Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit RETURN ' -----[noparse][[/noparse] BS2P Subroutines ]------------------------------------ #CASE BS2P, BS2PE, BS2PX Write_Byte: I2COUT SDA, ChipAddr, MemAddr.HIGHBYTE\MemAddr.LOWBYTE, [noparse][[/noparse]temp] RETURN Read_Byte: I2CIN SDA, ChipAddr+1,MemAddr.HIGHBYTE\MemAddr.LOWBYTE, [noparse][[/noparse]temp] RETURN #ENDSELECT
