A novel way to solder Surface Mount ICs
william chan
I was recently thinking of asking my PCB maker to coat all the pads on my board with a fairly thick amount of solder.
Then all I have to do is to dip the smd ic legs into flux before placing it on the pcb and then into the oven.
No need for solder paste or stencils.
You guys think it will work?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 7/1/2009 11:02:23 AM GMT
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
I looked into it a few years and still have two sample boards here at my desk. I have the spec on the flux and tried to source it myself to create boards with SSD so that a kit could be offered to someone. All you would need then is a toaster oven to make a professionally looking SMT board from a kit. The adhesive type flux at that time was almost impossible to source, so I gave up on the idea.
www.sipad.com/index.htm
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
It worked well.
www.fd.com.my
www.mercedes.com.my
There's nothing like a new idea and a warm soldering iron.
