BS2p40 questions
I am sure that questions very close to this have been asked several times, however after doing some searching i think i have a general idea, but want to confirm. I appoligize for the newbie questions.
I am planning on working with the BS2p40, and looking at the schematic i have a vew questions. My project will be running off of a 6v source (4x AA batteries) and my understanding is that this is within the voltage regulator on the module and shouldnt pose an issue. The second concern i have is that i am noticing that Pin4 and 39 are both VSS. Am i supposed to connect both to the negitive terminal? I am assuming that p4 is for serial data, and that p39 is what is connected to the negitive power source. The other question is with VDD / VIN. I may be wrong, but VIN is for regulated input, and since i am doing 6v i will be connecting to VDD and leaving VIN disconnected?
I appreciate any advice to help clarify these questions that i have.
[noparse][[/noparse]edit] Also the other question i have, is should i be doing anything to add protection to the VDD and VSS pins?
Post Edited (Loki008) : 6/30/2009 5:54:23 PM GMT
Vdd is the regulated +5V power supply input/output. In your case, this is the output of the regulator. You can leave Vin unconnected and provide a source of regulated +5V to Vdd. This is sometimes done when a large external regulator is used to supply both the Stamp and significant amounts of external logic. Sometimes two regulators are used. The one on the Stamp is used to power the Stamp while the external one powers the external logic. In this case, Vin is used and Vdd is left unconnected.
The two Vss pins are connected together on the module, but I'd also connect them externally. If you use a printed circuit board, run a trace between the two pins. If you're using a breadboard, connect them both to the same ground point on the breadboard.
If you plan to use NiMH rechargable AA cells, plan to use 5. NiMH cells have a terminal voltage of only 1.2V and 4 of them would provide less than 5V.
http://forums.parallax.com/forums/default.aspx?f=5&m=250265&g=250372#m250372
Basically i have been using a homework board but am designing a PCB that i want to get made up for a more finished result. I am also going to the p40 because i am planning on adding a few extras to the project such as the EMIC text to speach module and a few other goodies.
Here is a flickr photostream of the current version
http://www.flickr.com/photos/8834427@N04/sets/72157604260366787/
This is the project i am working on (this will be revision 3 of the project) yourself and several others have been quite helpfull in making sure that i dont fry everything.
So, if you want to do want to use AAs, the options as I see it are,
4 * L91 cells, (Energizer LiFeS2 primary cells, 1.5 volts, flat discharge curve)
5 * E91 alkalines
5 * NiMH or NiCd (flat discharge curve)
Tracy Allen
www.emesystems.com
http://www.radioshack.com/product/index.jsp?productId=2062599&tab=summary
Post Edited (Loki008) : 6/30/2009 7:25:42 PM GMT
