PIR to Relay
Hello,
I am trying·to switch a relay from the output of the PIR sensor. It seems that the PIR output is not enough to drive a 5v relay.
I can switch the relay from the output of a basic stamp but I would like to do this with just electronics.
I tried using an NPN transistor and I can light an LED from the transistor based on the input from the PIR but I still can't get it to switch the relay?
As you can tell I am not a EE but I wondering if there is some simple circuit or IC I can use for this?
-Mike
"Everything is working so why do we pay him?"
"Nothing is working so why do we pay him?"
-Mike
First let me thank you for your replys and posts. You have been very helpful to me in the past and I appreciate your contribution to the board. I read the link you suggested over and over yesterday as well as the links attached to it.
I tried the schematic from your post before I posted this one but I have several questions.
1. What transistors did you use.
2. Are the second and third transistors necessary?
3. How are the second and third transistors connected?
-Mike
2. I'd use both if you're going to drive a relay.
3. The three circles are the connections. I left them unconnected to indicate that you could choose between which circuit you wanted (PIR ON - other OFF or PIR ON - other ON).
Thanks again for your help.
-Mike
The problem I am having now is that sometimes the circuit works but most times the PIR goes into a loop and keeps triggering the relay.
I have attached a schematic with boxes representing the PIR and the transmitter. I have found that when I disconnect the transmitter the PIR stops looping.
Any Idea whats causing this?
I put an ocilliscope on the output of the PIR and it is indeed looping at a regular interval.
I will try the diode. Should it go between the relay trigger connections or the output/input of the relay?
- Stephen
I thought the same about the power I checked it and there does not seem to be a problem.
If I connect other circuits to the relay such as an led or a motor it seems to work fine.
-Mike
Thanks for your help,
-Mike
