XMM modules (RamBlade equivalent) etc — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2009-08-27 04:37 in Propeller 1
I thought I should start another thread for a different implementation of the RamBlade circuit. It is not right to continue to discuss this on Jazzed's thread, and it is a different physical·alternative to my RamBlade although the circuit has not changed.
While we are all after the same objective, that being access to external ram (XMM), we are taking different approaches·because of·different end use requirements. The prop community will be the benefactors of these alternative developments. Requirements...
  • XMM for C, spin, and LMM pasm
  • Emulators such as ZiCog, MoCog
  • PropOS (a propeller operating system)
  • Video buffering is a possible 4th·
I am building·1.3"x1.3" pcb modules with a 12x12 set of pins around the outer edge. They·can plug into a Prop ProtoBoard or be standalone. Modules will be mainly smt and will be available as pcb or prebuilt and are...
  • A prop, eeprom, xtal -·equivalent to the center section of a Prop ProtoBoard
  • A·512KB SRAM, 1 microSD socket, 1 secret miniature chip (don't ask)
  • A·proto pcb (12x12 =144 pins) for prototyping 1 off designs
  • Maybe·a power supply and USB (FT232RL) PropPlug equivalent
  • Maybe smaller pcbs to plug in
    • vga
    • keyboard & mouse
    • others???
Purpose... one prop pcb + one sram pcb = 1 RamBlade. It can plug on top of a prop Proto board. You can stack them. You can rotate them. You can build a latch(es) on the proto section. Cheap and modular solution for experiments.
Pinouts can be seen in the bmp below. The corner pins are left for special connections.
RAM MODULE: 512KB SRAM & microSD: Pinouts D0-D7=P0-P7, A0-A18=P8-26, CS/WE/CE(order may vary)=P27-29, SO/SI=P30-31(not used). When connected this way, a PropPlug and Eeprom can be used. However, when rotated to be A0-A18=P0-18, CS/WE/CE(order may vary)=P19-21, SO/SI=P22-23(not used), D0-D7=P24-31 the normal Eeprom and PropPlug cannot be used BUT the·sram access speed is improved. Should a proto·module be interposed between this and the prop, latches or CPLD's can be used.
4 concept modules are shown·below·- left to right is... proto, prop/eeprom/xtal, sram/uSD, power/usb. Nothing is physically placed on the modules.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
Post Edited (Cluso99) : 6/26/2009 7:24:40 AM GMT
