Infrared Detection
Um i was working on a javelin implementation of the boe's ping and ir object avoidance program and upon checking the api for the freqout, the max is 12 KHz, and the ir is at 38500 Hz, any tips/ aid on how to do this?
Thanks in advance.
Thanks in advance.
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/JBot/
There are IR detect classes and explanotary texts.
Note that the pictures in the pdf files are missing.
You can use the Robotics files (the javelinbot files are reworked robotics texts)
to get the pictures if necessary.
regards peter
http://forums.parallax.com/showthread.php?p=578038
http://forums.parallax.com/showthread.php?p=631354
regards peter
Thanks to the Javelin, servo movements are more " synchronized" than a basic stamp version
I added some documentation regarding connections.
Please check if these are correct.
regards peter
Note: because the 38.5 khz, approx. is not a harmonic frequency,but a direct pwm, the ir's are much more sensitive than with a basic stamp, gives about a 5-8cm for me
Post Edited (modkil) : 6/26/2009 6:01:58 PM GMT
