the eeprom i use on the propmod are rated to 1M writes. Unless you are writing a lot to them wearing out is not a problem. Will last 10 years if you keep it under 273 writes a day.
propmod_us and propmod_1x1 are temporarily out of stock(selling faster then expected). Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Yep .. I use the Ramtrons as well.
What driver do you use? The basic i2c seems to be a bit slow. Is there a driver which can read/write at max. speed of a Ramtron?
Doesn't one write to an EEPROM count as 2 write cycles? First it has to be cleared, then the data is written. Plus .. the given number of write cycles is an average. I remember a AVR microcontroller that I used, which had a broken flash after a few month of development. Number of write cycles by far not reached.
They sent me samples 6 months ago for all of their FRAMS.
If they give you trouble, send me an Instant Message or PM, as it is called. I have oodles of samples and carrier (adapter) boards.
It's common practice to read a location in EEPROM before modifying it so there's a write cycle only when the value changes.
READ location,contents
IF newContents <> contents THEN
WRITE location,newContents
ENDIF
Rich H
Or do I mix this up with flash memory?
JMH
Post Edited (MagIO2) : 6/22/2009 7:23:36 AM GMT
I went to the manufacturer's page to read up about those frams you mentioned. They claim
"High Endurance 100 Trillion (1e14) Read/Writes".
That is really superior to eeprom!
Gonna call them and see if I can beg a sample or two.
Thanks for mentioning them
JMH
Thanks!
If I can't get any samples I will PM you and you could send them to my house or where I work
Maybe it was just one of the products I was looking for...
Nyamekye,
Arrow Electronics is the distributor. Try www.findchips.com.
JMH
